Turbo Supercharged G60
Engines, induction, tuning, cooling, sensors and all things under your bonnet!
Proudly sponsored by:-
Postby BeavisJem » June 8th, 2006, 9:41 am
Just wondering if anyone here knows of anyone who has done it, it seems some of the supers cars use a turbo super setup. Just wondered how easy it would be to do?
Beavisjem
Black 1992 G60 Corrado, 68mm Pulley, Chip, K&N, Boost return mod, 17" RS4 wheels, G60 FMIC.
User avatar
BeavisJem
:: CF Enthusiast ::
:: CF Enthusiast ::
Gender: Male
Postby GazzaG60 » June 8th, 2006, 9:45 am
not with a G60 charger anyway.
G60 RIP
16vt - the rug got pulled
S2 coupe - onward and upward.
GazzaG60
:: CF Nutter ::
:: CF Nutter ::
Postby kevhaywire » June 8th, 2006, 9:46 am
I think there's a guy called G60IHI that has a turbo'd G60 engine. Around 300hp IIRC.
94 VR6 Turbo
User avatar
kevhaywire
:: Super Mod ::
:: Super Mod ::
Gender: Male
Postby Blue_Joe » June 8th, 2006, 9:55 am
GazzaG60 wrote:not with a G60 charger anyway.
I don;t see any reason why you couldn't do it with a G-Lader. Just need the right ECU to be able to set it all up with
2Ltr 8 Big Valves G60 Conversion DONE - 245bhp / 246lbft of Torque
SHES A TORQUE MONSTER!!!!!!!!!!!!!
http://i99.photobucket.com/albums/l302/ ... meOut1.jpg
User avatar
Blue_Joe
:: CF Donator ::
:: CF Donator ::
Postby Henny » June 8th, 2006, 12:20 pm
it's called compound charging...
VW are building 1.4 compound charged engines for the new golf which produce a healthy 170bhp!
AW tracksport (TrendyTramp over on Dubforce) has built a couple of engines which are compound charged... If you've been to any of the big shows over the last couple of years, you've probably seen their metallic red, fully caged MKII golf which had no front end other than the cage. That's got their compound charged engine in it... 8)
There's no reason a G60 supercharger couldn't be used, in fact, it'd probably work rather well with a small pulley to give massive low end power... you'd then put a clutch on the charger pulley so that when the boost from the turbo kicks in and matches that from the G60, it'd stop spinning the supercharger and just rely on the boost from the Turbo...
Should make for a rather special combination if you can get it set up properly, it's just a case of working out who to get it to swap between the supercharger and the turbo without any loss of boost.... 8)
W-VHN - '00 Passat TDI 115 Estate - The 190,000 mile Load Lugger!
H-YYU - '91 Pearl Grey G60... was 251.7 BHP now engine-less
J562DUB - Aqua blue G60 - RIP
H714HKC - Tornado Red 1.8 16V - RIP
User avatar
Henny
:: CF Addict ::
:: CF Addict ::
Gender: Male
Postby GazzaG60 » June 8th, 2006, 12:38 pm
id stick to an eaton for it. no point breaking a G lader. they are either gated or clutched. id expect you would need an actuated charger to release pressure or allow it to stop working. the actuator could be controlled to allow smooth power transition. you may as well just use a good turbo though and put up with a 1000rpm or so of lag. its the old 80-20 rule.
G60 RIP
GazzaG60
:: CF Nutter ::
:: CF Nutter ::
Postby carpoid » June 9th, 2006, 12:56 pm
Hows this ..... !!
ImageEX '92 G60
User avatar
carpoid
:: CF Subscriber ::
:: CF Subscriber ::
Gender: Male
Postby DaveVR6 » June 9th, 2006, 1:44 pm
Theyre also building a 2ltr to go in the mk6 golf, god knows what power thats gonna put out
User avatar
DaveVR6
:: CF Enthusiast ::
:: CF Enthusiast ::
Postby BeavisJem » June 9th, 2006, 3:17 pm
carpoid wrote:Hows this ..... !!
Can you give me any more info about this car?
Wonder what kind of power its pushing?
Bevaisjem
User avatar
BeavisJem
:: CF Enthusiast ::
:: CF Enthusiast ::
Gender: Male
Postby biggerbigben » June 9th, 2006, 3:23 pm
Its Roy Kenton's Mk4.. don't think its finished yet.. he is friends with JD Engineering.. should be good for 500+ bhp I would have thought.
Ben
http://www.coupehaus.com
Then - Corrado AWD 20vt TVR Interior - SOLD
Then - Mk4 Track Car - SOLD
Now - Finishing R32 Storm, working on 600+bhp R32Turbo mkiv
Now - Planning a major project that will keep me busy for years to come ;-)
User avatar
biggerbigben
:: CF Nutter ::
:: CF Nutter ::
Postby Henny » June 9th, 2006, 4:13 pm
20VTG60?!? Woah! Cool... 8)
User avatar
Henny
:: CF Addict ::
:: CF Addict ::
Gender: Male
Postby kevhaywire » June 9th, 2006, 4:34 pm
What's the G lader's max cfm?
94 VR6 Turbo
User avatar
kevhaywire
:: Super Mod ::
:: Super Mod ::
Gender: Male
Postby Jim » June 9th, 2006, 4:40 pm
Bloody hell.. well there's something novel! Wonder how far away it is from being done..?
| Currently: 1994 Corrado 2.0 16v (Flash Red) | 1995 Corrado 2.9 VR6 (Classic Green) |
| Corrado's Previously owned :- Corrado G60 (pic) and Corrado 2.0 16v (pic) |
User avatar
Jim
:: Super Mod ::
:: Super Mod ::
Gender: Male
Postby BeavisJem » June 9th, 2006, 5:54 pm
SOOOOO tempting to try and do this.
Anyone know how you could link up a clutch system to the g lader to kick in a certian revs?
Or does anyone know how to start finding out how to do this?
User avatar
BeavisJem
:: CF Enthusiast ::
:: CF Enthusiast ::
Gender: Male
Postby B4LJX » June 9th, 2006, 6:03 pm
this is a uk car??? i've seen this on other sites saying its a guy in austria???
User avatar
B4LJX
:: CF Regular ::
:: CF Regular ::
Next
Return to Engine Bay
Who is online
Users browsing this forum: Dude VR6, Hatcha, nemesis360 and 1 guest
