Results 1 to 10 of 10
Thread: High revs
  1. #1
    ⋆⋆ CF Member ⋆⋆
    Join Date
    11th May 2012
    Posts
    162
    High revs
    Hi all,
    Any ideas as to what I need to look at on my vr6 - on start up it has an annoying habit of going straight up to 2.5 revs before settling down - it runs fine other than that but it makes it look as if I don't know how to start a car!!
    Thanks,
    Tim.
  2. #2
    CF-oholic! fla's Avatar
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,159
    Maybe some air leak on the intake elbow. Throttle body might need to be cleaned out
    Hasan
    VR6 Auto to manual conversion, beige leather, aircon, TT comps, blue dash lights & switches, Koni TA/Nothelle springs, OBD2, 264 cams
    my car
  3. #3
    ⋆⋆ CF Member ⋆⋆
    Join Date
    11th May 2012
    Posts
    162
    Thanks, I'll check both those now it's off the road for winter.
  4. #4
    ⋆⋆ CF Donator ⋆⋆ robrado974's Avatar
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    5,793
    Also check the sender to the block , the one that sends the signal to the ECU.
    92 VR6 . DBP. She will never be a show car ..... But will be up there with the best of em .
    The bmw seems invincible in isolation . But along side the corrado - a modern classic , we think- it has its work cut out . Autocar 1992.
  5. #5
    ⋆⋆ CF Member ⋆⋆
    Join Date
    11th May 2012
    Posts
    162
    I take it you mean the blue temp sensor? I thought I might change it regardless so that makes me feel a bit better!
  6. #6
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    5,793
    Quote Originally Posted by Tjninny View Post
    Yes that’s the one . You may as well change the other two while your at it
  7. #7
    ⋆⋆ CF Member ⋆⋆
    Join Date
    11th May 2012
    Posts
    162
    Will do, cheers.
  8. #8
    Check your TPS as well. Your way better than mine. One day it just decided to hesitate majorly and still haven’t figured out what’s causing it. TPS is new and disconnected.
    Pro
  9. #9
    ⋆⋆ CF Member ⋆⋆
    Join Date
    11th May 2012
    Posts
    162
    Cheers Mark, will do.
  10. #10
    ⋆⋆ CF Member ⋆⋆ vw rule's Avatar
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    903
    Sounds like your cold start programme is possibly over compensating, like too much fuel or fast idle is lingering on too long.
    Coolant temp switch, as mentioned already.
    Throttle body clogged up.
    Idle control valve sticking.
    Air flow meter.
    With the engine turned off check that you have good full throttle movement,
    by operating the throttle linkage by hand from closed position to full open position, you should also here a slight clicking sound from the throttle position switch. The throttle movement should be fairly smooth & even.
    Have you got a diagnostic scanner, or is there someone off this Forum close to where you are who has one ?
    Or take it to your local garage.
    Hope this helps.
    Si
Similar Threads
  1. Flat at high revs...
    By MurphG60 in forum Engine Bay
    Last Post: 28th March 2007, 11:54 PM
  2. VR6 missfire at high revs
    By olly elworthy in forum Engine Bay
    Last Post: 3rd May 2006, 12:17 PM
  3. revs too high
    By maximus2029 in forum Engine Bay
    Last Post: 21st February 2005, 11:06 AM
  4. revs too high on start
    Last Post: 20th February 2005, 8:41 PM
  5. Revs too high and stays high........
    Last Post: 21st December 2004, 2:41 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
