Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: Lots of Good Original VR6 Parts , some new
  1. #1
    ⋆⋆ CF Donator ⋆⋆ GrahamV's Avatar
    Join Date
    3rd August 2017
    Posts
    104
    Sold
    Search other list
    Corrado VR6 original working serviceable Used Parts, some new.
    All items on a first come basis.
    First to commit to buy taking precedence over request for further information or photos etc.
    Collection from North Staffordshire near Leek or post at cost
    Please request/reply on this thread for me to update and PM confirmations
    Regards Graham V
    Full page photo (9).jpg Full page photo (10) (2).jpg Full page photo (10) (6).jpg
    Full page photo (10) (4).jpg Full page photo (10) (3).jpg Full page photo.jpg
    Full page photo (2) (7).jpg Full page photo (2) (6).jpg Full page photo (2) (4).jpg
    Full page photo (2) (5).jpg Full page photo (2) (3).jpg Full page photo (2).jpg
    Full page photo (2) (2).jpg Full page photo (3).jpg Full page photo (3) (2).jpg
    Items available
    1 Radiator OE £15.00
    1 Rad top elbow @2.00
    1 Wishbone Front Lower LH VR6 £15.00
    1 Wishbone Front lower RH VR6 £15.00
    25 Wheel bolt M12 x 1.5 not vr £10.00set
    2 HUB CV Joints Re Finished £10.00 pair
    2 Front hubs 5 stud with ABS ring working ok, were corroded now plated & rust free £10.00 pair
    1 Servo 9" MK3? golf Golf £10.00
    1 Clutch cloth covered feed pipe £3.00
    1 Exhaust Sys cat backwards Powerflow £50.00
    1 Exhaust section fits after CAT VR6 MK2 1992 good quality £20.00
    1 Roof Gutter Rail RH edges frayed £10.00 535853706 01C
    1 Roof gutter Rail LH edges frayed £10.00 535853705 01C
    1 Roof Gutter Rail hinge cover RH £2.50ea 535853720 01C one tab broken
    1 Roof Gutter Rail hinge cover LH £2.50ea 535853719 01C one tab broken
    1 Grille only VR6 MK2 1992left tab broke £10.00
    2 VW Grille centre Badge good ones £10.00
    1 RH & LH Drop Glass felt lined door frame seals good no tears or scrapes inner pair £40.00 outer pair £60.00
    1 LH & RH Door aperture seals good £30.00 pair
    2 Screen top cover seal £5.00each
    1 LH Outer door drop glass Slot seal £20.00
    1 RH Outer door drop glass Slot seal £20.00
    1 LH Inner door drop glass felt scraper seal £10.00
    1 RH Inner door drop glass felt scraper seal £10.00
    1 LH Drop Glass Green light scratching £20.00 535845021A
    2 RH Drop Glass Green light scratching £20.00 535845022A
    1 Tailgate glass green 2 filaments need attent £60.00 535845501A
    1 Master cyl plastic reservoir no cap NEW Non ABS £10.00
    2 LH door bump protector strip Mk2 NEW £46.85 sell £30.00 535 853 515A
    2 LH door bump protector strip NEW NOS MK1 £20.00 535 853 515 2BC
    1 LH wing bump protector MK2 £12.00
    1 LH rear 1/4 bump Protector MK2 £15.00
    1 RH rear 1/4 bump Protector MK2 £15.00
    1 RH wing bump protector MK2 £12.00
    1 Tailgate lower trim black all intact no clips £10.00
    1 Bonnet insulation after market waffle pattern £20.00
    1 Bonnet latch Re finished £10.00
    1 Bonnet Pin Re finished £10.00
    1 Throttle Body VR6 MK3 3 pin ODB1 £20.00
    1 Fuel Filter clamp bracket re finished £3.00
    1 First aid kit MK1 & Scirrocco NEW in soft red pouch £20.00
    1 Warning Triangle 1992on £10.00
    1 Warning Triangle MK1 & Scirrocco £10.00
    1 Head lamp dash switch all good £25.00 ea
    1 Heated rear screen dash switch all good £15.00 ea
    1 Fog Lamps dash switch all good £18.00 ea
    1 Indicator stalk no hazard cowl £10.00 ea
    1 MFA Steer wheel stalk £10.00
    1 LH Indicator MK2 £20.00 crack/marked
    1 RH Indicator MK2 £25.00 worn but no cracks
    1 RH rear Stop Lamp/Indicator Good small crack £15.00
    1 LH rear Stop Lamp/Indicator V Good £20.00
    1 LH rear lamp tailgate V Good £15.00
    1 RH rear lamp tailgate v Good £15.00
    1 Pair Wing Side repeater lens Orange OE Hella £5.00 pair
    1 LH Mirror Casing, broken trim (also fits TVR’s) @£15.00
    1 set 6 Rear bumper body Clips £10.00 set
    1 set Front Bumper hangars Clips damaged £10.00
    1 Fan blower motor working £5.00
    1 set Fanfare horns rusty no bracket all ok working fine £10.00
    1 set Bumper fixing wedges £5.00
    1 set bonnet heated water jets £10.00
    2 Door check strap seals £1.00
    1 Set Door glass triangle seals £5.00 set
    10 Body OE aperture seals 40mm £10 for the lot
    6 Fuel injectors £40.00/set of 6
    1 RH Rainwater scuttle cover no clips £5.00
    2 ARB drop links & clips £5.00 pair
    2 Door end bungs £4.00 pair
    1 RH footwell airvent @£2.00
    1 Scuttle water tray seal 535819521 @£5.00
    1 Rear brake equalizer bolt £1.00
    1 Rear brake spring £1.00
    1 Tool kit strap £4.00
    1 Tailgate loom rubber @£2.00
    1 Gear box mount remote plastics £5.00
    1 Gear box 1st syncro and others £5.00
    1 Front disc dust shields powder coated not VR6 £10.00 set
    1 Power steer res & cap £5.00
    Attached Images Attached Images
  2. #2
    Loads of stuff
    After a lot lol
    Where do you live? If is near me I’ll drive and look
  3. #3
    Can I have the
    Manifold heat shield
    Fuel tank straps (are they for a vr6?)
    The wing mirror glass both left and right?
    Coolant bottle
    Bonnet cable and mechanisms
  4. #4
    ⋆⋆ CF Member ⋆⋆ Storm Warning's Avatar
    Join Date
    16th January 2003
    Location
    East Mids
    Posts
    530
    Quite a garage full you have! How much for this lot?
    Out of interest how much for the whole listing?
    Many Thanks :-)
    2 Lower wishbone Ball Joint VR6 New Febi
    2 set ABS sensors rear VR6 MK2 1992 USED
    1 SONY CD Player fits corrado with loom
    1 Fischer C Box 3 tape box £25.00 535 864 117A
    1 Exhaust Rear heat shield VR6 MK2 1992 NEW- VW OE NOS £236.80 £160.00 1H0 804 155A
    1 Exhaust manifold set VR6 Re Finished £25.00 021 253 031C & 021 253 032E or N 013 814 9 or N 902 889 01
    1 Exhaust manifold warm air deflector plate VR6 Re Finished £15.00 021 253 037E
    1 Exhaust hangars VR6 MK2 1992 USED
    1 Exhaust hangars GOLF VR6 NEW- VW OE NOS £5.00 OE
    2 Exhaust Clamp 64.5mm Corrado Golf NEW- VW OE NOS £5.00 535 253 139 OE
    1 Roof Gutter Rail RH VR6 MK2 1992 New & complete £124.00 £65.00 535853706 01C really good After market by Karmanski
    1 Roof gutter Rail LH VR6 MK2 1992 New & complete £124.00 £65.00 535853705 01C really good After market by Karmanski
    1 Roof Gutter Rail End cap RH VR6 MK2 1992 NEW OE £8.26 £6.00 535853720 01C
    1 Roof Gutter Rail End cap LH VR6 MK2 1992 NEW OE £8.00 £6.00 535853719 01C
    2 Seat belt bolt cover VR6 MK2 1992 NEW
    1 Head lamp surround LH VR6 MK2 1992 NEW- VW OE NOS £31.50 535941177B
    1 Head lamp surroundRLH VR6 MK2 1992 NEW- VW OE NOS £34.95 535941178B
    1 Set Head lamp surrounds clips VR6 MK2 1992 NEW- VW OE NOS
    1 RH Head glass VR6 MK2 1992 NEW- VW OE NOS
    1 Set Head lamp Relay Loom VR6 MK2 1992 NEW
    1 LH & RH Blue Mirror Glass heated NEW
    1 LH & RH Blue Mirror Glass heated OE USED
    1 RH Drop Glass SLOTSEAL outer Corrado 1991-1995 NEW unused £48.95 £40.00
    2 Roof drain rear 1/4 Grommet USED
    1 Coolant Bottle - Round Corrado Golf NEW Myele Round
    1 Thermostat housing VR6 Corrado Golf NEW Top Ran boxed
    2 Coolant Bottle Mount Studs Corrado Golf NEW- VW OE NOS
    1 CV Gaiter set VR6 MK2 1992 NEW
    2 ABS pipe clips VR6 NEW- VW OE NOS Bulkheads ones
    1 Fuel Tank Straps set 70 litre Corrado Powder coated 535 201 654 & 535 201 653
    1 Fuel Filter Plastic Cover VR6 MK3 NEW- VW OE NOS
    1 Rear VW Badge Roundel NEW 191-853-601BGX2
    4 Door rod clips Corrado NEW
    4 Door handle white clip Corrado NEW
    4 Small heatshield clips Corrado NEW
    1 Aerial Gasket kit Corrado NEW
    1 Heater Matrix Corrado UNUSED
    1 Various coolant hoses Corrado NEW
    2 Rear Brake Hoses Corrado NEW
    2 Rear ABS Plastics Corrado Used
    My Storm HERE | 17" BBS RCs | Aero Wipers | BMC CDA | 19 Row Mocal | KWs | 312 Fronts | 263 cams | EVO Featured
    AM V12 Vantage | Meteorite Silver | B&O | Carbon Seats
    RS4 | MY15 | Daytona Grey | Sports Pack
    Caterham R460 Superlight | Track toy
  5. #5
    I'll take the Front L & R indicator units please just let us know payment details
    Bunny
  6. #6
    CF-oholic! delfinis38's Avatar
    Join Date
    24th February 2006
    Location
    Muckle Flugga & Fastnet Rock
    Posts
    3,229
    Ha ha.. and I thought I was bad at collecting parts.
    Corrado VR6 - Aqua Blue LC5U - 96 'N' Plate
    Black Leather - Heated Seats - Air Con
    Totally Standard and intend to keep it that way !
    Hibernation for Winter ! SORN
  7. #7
    ⋆⋆ CF Donator ⋆⋆ robrado974's Avatar
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    5,962
    Can I take the new end caps for the roof rails please .
    92 VR6 . DBP. She will never be a show car ..... But will be up there with the best of em .
    The bmw seems invincible in isolation . But along side the corrado - a modern classic , we think- it has its work cut out . Autocar 1992.
  8. #8
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st December 2004
    Location
    Roma,Italy
    Posts
    1,994
    Photo of the handbrake cowl? Black? any cracks or splits?
    Cheers.
  9. #9
    There seem to be a pair of VR6 headlamps in the list, are they late model compatible and in good shape?
    (Oops, just noticed collect only; can't collect just for those...)
    [ WARNING: the above message may contain irony, sarcasm and outright lies. ]
    ** Every time you think about sex, another Corrado gets written off. **
  10. #10
    CF-oholic! fla's Avatar
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,262
    New Roof gutter rails please both sides if still available
    Hasan
    VR6 Auto to manual conversion, beige leather, aircon, TT comps, blue dash lights & switches, Koni TA/Nothelle springs, OBD2, 264 cams
    my car
Similar Threads
  1. Replies: 97
    Last Post: 10th October 2016, 2:56 PM
  2. Replies: 20
    Last Post: 11th May 2016, 1:42 PM
  3. Lots of vr6 turbo parts.
    By vr6turbo in forum Parts for Sale
    Last Post: 12th November 2013, 9:35 PM
  4. Tornado Red parts and lots of other parts going cheap!
    By Marshall936 in forum Parts for Sale
    Last Post: 1st August 2013, 3:18 PM
  5. lots of parts needed1 16V
    By KHAWAR16 in forum Wanted
    Last Post: 22nd March 2011, 10:53 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
