Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: G60 carbon canister removal
  1. #1
    Guys, I know this can be binned from the engine bay of a G60, but just wanted to see what needs to be removed and what needs to be blanked
    Does anyone have any pictures or a guide on removal of it?
    Thanks
  2. #2
    Enthusiast Gti_Jamo's Avatar
    Join Date
    4th October 2012
    Location
    Perthshire SCOTLAND
    Posts
    558
    Basically there are two pipes that go the the throttle body (large and small) and and another on the front of the inlet manifold plumbed into the servo vacuum pipe than need removed and blanked off. The easiest way would be to cut small sections off the original CC pipework and block them with suitable sized bolts. There is also a breather pipe coming from the fuel tank which needs to breath. Some put a little filter on it and route it underneath the airbox. Theoretically it could be plumbed into the bottom of the airbox too and just recirculated that way. There was an diagram floating about the web for it but can't seem to find it now. Probably lost with all the rest of the photobucket images I assume.
    MY 1991 G60 CURRENTLY IN RESTORATION
    http://the-corrado.net/showthread.ph...-Daily-Project
  3. #3
    ⋆⋆ CF Member ⋆⋆ STU175's Avatar
    Join Date
    31st January 2008
    Location
    Ipswich, Suffolk
    Posts
    586
    G60-1991-Alpine White-JMR Stage 4 charger-JMR Big Valve Head-Schrick 268/276 Cam-forged 83mm pistons-forged conrods-lightened and balanced bottom end-Wagner I.C-Oil cooler-Smoothed bay
    link to build thread http://the-corrado.net/showthread.ph...TE-G60-UPDATED
  4. #4
    Cheers for the help guys.
    Have removed it all now.
    Small vacuum on the back of the throttle body called. Larger one on the side of the throttle body called. The one that's on the front of the inlet (in the middle) has been called off.
    My only question is the one that's on the brake servo line that loops into the inlet manifold on the end, is that to now be capped off completely or looped back in?
  5. #5
    Join Date
    31st January 2008
    Location
    Ipswich, Suffolk
    Posts
    586
    Quote Originally Posted by BarberG60 View Post
    Dont get wot u mean stick up a photo of it and ill try to help
  6. #6
    That should read capped, not called. That's predictive text for you and me not checking.
    I will get a pic up tomorrow when it's light again, but I am left with an open vacuum coming from the shutoff valve. Wasn't sure if I cap it or loop it back in somewhere
    When started the idle shoots up to 2k now so it's obvious that it can't stay open due to the air leak.
    I'll grab a picture.
    Thanks
  7. #7
    Join Date
    31st January 2008
    Location
    Ipswich, Suffolk
    Posts
    586
    Thanks
    Ahh i no which one you mean. Block it off.
  8. #8
    Join Date
    31st January 2008
    Location
    Ipswich, Suffolk
    Posts
    586
    This is how my one is done
  9. #9
    This is the one. I just cap this one off?
    https://www.flickr.com/photos/153765.../shares/rX34y5
    I've also got a vacuum line that seems to run right to the back of the back, maybe the dash MFA vacuum?
  10. #10
    Join Date
    31st January 2008
    Location
    Ipswich, Suffolk
    Posts
    586
    Cap it off or replace with new piece of hose m8
Similar Threads
  1. carbon canister removal
    By golf301 in forum Engine Bay
    Last Post: 14th July 2007, 9:09 PM
  2. Carbon canister removal
    By Matt-lmr in forum Engine Bay
    Last Post: 27th February 2007, 9:21 PM
  3. carbon canister removal
    By g60griff in forum Engine Bay
    Last Post: 13th August 2005, 12:35 PM
  4. Replies: 3
    Last Post: 28th March 2005, 5:01 PM
  5. Carbon Canister Removal/Relocation VR6
    By Joe M in forum Engine Bay
    Last Post: 7th March 2005, 11:53 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
