Results 1 to 7 of 7
Thread: ABS pump outlet unions
  1. #1
    Newbie
    Join Date
    7th August 2017
    Location
    Nottingham
    Posts
    27
    I've changed a couple of brake lines today, however the fitting/union on the ABS pump for the rear left is larger than the other three outlets - 12mm as opposed to 10mm. The others have all previously had the original lines replaced.
    I found a photo of a pump on another forum, but it also looks like mine, with the rear left union being a larger diameter.
    Can anyone advise whether this normal, or that all the original lines had 12mm fittings.
    And, if possible - where can I get a union from to convert it to accept the 10mm brake pipe fitting?
    1993 Corrado 16v
  2. #2
    Enthusiast Gti_Jamo's Avatar
    Join Date
    4th October 2012
    Location
    Perthshire SCOTLAND
    Posts
    496
    It's common on VW's for one or 2 of the unions to be larger on the ABS pumps. I'm not sure why but I have encountered it a few times over the years. Not sure if you can get a converter union, you may need to replace the union on the pipe with a 12mm.
    MY 1991 G60 CURRENTLY IN RESTORATION
    http://the-corrado.net/showthread.ph...-Daily-Project
  3. #3
    Newbie
    Join Date
    7th August 2017
    Location
    Nottingham
    Posts
    27
    Thanks
    I think I've found an adaptor to reduce from 12 to 10mm, will update when I've fitted it, fingers crossed....
    1993 Corrado 16v
  4. #4
    Yes this seems to be normal, mine is like it and at first I assumed someone had oversized it at one point due to a damaged threat. But now I think it may be so you know which line feeds which rear brake.
    When I replaced my brake lines a few months ago I got the correct size male end off of ebay. I think they were m12x1.0 3/16 unions.
  5. #5
    Regular
    Join Date
    23rd April 2017
    Location
    Liverpool
    Posts
    194
    I work for a Renault dealership and the larger brake pipe union is the brake fluid feed from the brake master clylinder. Which allows more brake fluid though. But this may not be the case for VW.
  6. #6
    Quote Originally Posted by 1200 bandit View Post
    Not the same on the corrado, the feeds might have larger unions (can't remember right now) but the one being discussed is one of the rear brake lines.
  7. #7
    Newbie
    Join Date
    7th August 2017
    Location
    Nottingham
    Posts
    27
    M12x1 to M10x1 reducer fitted - all sorted
    I've replaced a few brake pipes for the upcoming MOT, whilst bleeding the rears I found brake pipes on top of the axle had been crushed by the body where it was set so low on the coilovers. I raised it shortly after buying, t'was tooooo low....
    1993 Corrado 16v
Similar Threads
  1. G 60 rs outlet
    By waski186 in forum Parts for Sale
    Last Post: 12th April 2013, 10:14 AM
  2. RSR outlet
    By owen g60 in forum Wanted
    Last Post: 21st September 2011, 6:08 PM
  3. Replacing/repairing fuel line unions
    By Thom in forum Engine Bay
    Last Post: 8th March 2011, 11:37 AM
  4. ABS Unit, different sized unions, why?
    By KipVR in forum Drivetrain
    Last Post: 10th November 2008, 11:09 PM
  5. RSR outlet... how much does it really do????
    By CorradoKid05 in forum Engine Bay
    Last Post: 2nd August 2003, 5:07 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
