Results 1 to 10 of 10
Thread: RE Advice on how to take oil cooler off/apart - 1.8 16v
  1. #1
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    11th March 2009
    Location
    West Midlands
    Posts
    4,229
    Hello again all
    this time im asking for help on my valver, 1990 1.8 16v
    i think ive located my oil leak - seems to be coming out of the top of the oil cooler, between the cast part & the metal cooler
    ive got an O ring on order, the one that sits between the 2 bits mentioned above
    ive looked at what i think is a schematic of the cooler but thought id ask if anyone knows how they come off?
    it looks like i remove the oil filter & then there is a nut that holds the cooler on via a central shaft
    i guess i undo that, unclip that feed & return hoses & then slide it down
    any input would be appreciated
    thanks
    Bramber metallic VR6 bring on the grins as the VR sings!!!!
    Stealth head rebuild, 263's, BMC CDA, Roose M/Sport hoses, VT engine mount, KW V1s
    KUR2Y loom, daves16v short shifter, 2.5" Longlife SS exhaust with sport cat, lots of shiny bolts & 210bhp
    Alpine White 1.8 16v, Kamei skirts, Powerflow SS exhaust, back on my drive April 2014
  2. #2
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st December 2004
    Location
    Roma,Italy
    Posts
    2,009
    That's basically it mate, I'd also unscrew the center threaded shaft as it makes it easier to relocate the cooler and the orings.
    Ideally i'd fit a proper Mocal or similuer cooler and get rid of the original version, they are known to break and make a huge mess when the oil mixes with the cooling water..
  3. #3
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    11th March 2009
    Location
    West Midlands
    Posts
    4,229
    Quote Originally Posted by VEEDUBBED View Post
    tidy thanks veedubbed
    i can get a new cooler for £23 so might invest in that whilst im there. also may as well do a service as it needs on & im likley to need to drain the oil out anyway
  4. #4
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    11th March 2009
    Location
    West Midlands
    Posts
    4,229
    on the point of servicing - anyone know how much oil the 1.8 16v takes for an oil change?
    hopefully not just over 5 litres like the VR lol
  5. #5
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    11th March 2009
    Location
    West Midlands
    Posts
    4,229
    Quote Originally Posted by g0ldf1ng3r View Post
    tidy - wiki to the rescue - 4.5 litres according to the oil change jobbie
  6. #6
    Regular
    Join Date
    8th July 2003
    Location
    Hilton
    Posts
    105
    From memory the nut that holds the oil cooler on is in the region of 24mm (but could be as big as 28mm). If you measure up and get the correct sized deep socket it makes the job a lot easier, especially getting the correct torque on reassembly.
    An oil change on a 2.0 16v is normally 4 litres, I'd imagine a 1.8 is similar.
    Neil
  7. #7
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    11th March 2009
    Location
    West Midlands
    Posts
    4,229
    can anyone tell me what size the nut is that holds the oil cooler on pls?
    one place is saying 24mm but another says 27mm - both of which are bigger than those in my socket set so will need to buy one for this job
  8. #8
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st December 2004
    Location
    Roma,Italy
    Posts
    2,009
    Your gonna need that socket the long/deep variety too, no way a normal socket will clear the threaded pipe bit.
    Tomorrow morning I'll measure a few I have spare but 99% it's a 24mm size.
  9. #9
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    11th March 2009
    Location
    West Midlands
    Posts
    4,229
    excellent thanks Veedubbed, much appreciated
  10. #10
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st December 2004
    Location
    Roma,Italy
    Posts
    2,009
    Right, i've Got a few spare 'raddo engines in bits.
    Both late 2.0 valver 9A's have a 27mm nut holding the cooler in place but the other older KR mill has a 24mm version.
    Disregard what I said about the deep socket, I needed that when I fitted a Volvo oil cooler onto my turboed 16v years back, you'll be fine with a normal socket.
Similar Threads
  1. Oil Cooler Advice ?
    By Alty in forum Engine Bay
    Last Post: 25th March 2016, 10:49 AM
  2. Oil cooler advice?
    By Hofmiester in forum Engine Bay
    Last Post: 4th August 2013, 11:51 AM
  3. OIL cooler advice
    By owen g60 in forum Engine Bay
    Last Post: 2nd April 2012, 5:24 PM
  4. G60 Oil cooler fitting advice needed !
    By flatg40 in forum Engine Bay
    Last Post: 16th November 2008, 6:38 PM
  5. toad ai606 lock advice and box location advice
    By elrikos in forum ICE 'n' Secure
    Last Post: 19th June 2006, 10:38 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
