Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: VR6 Various seviceable parts remaining
  1. #1
    ⋆⋆ CF Donator ⋆⋆ GrahamV's Avatar
    Join Date
    3rd August 2017
    Posts
    125
    SEE NEWER POST FOR ITEMS STILL LEFT
    Corrado VR6 original working serviceable Used Parts, a few new items too.
    Looking to clear remaining parts.
    All items on a first come basis.
    First to commit to buy taking precedence over request for further information or photos etc.
    Items in photos but not listed below are already sold
    Collection from North Staffordshire near Leek or post at cost.
    Please request/reply on this thread for me to update list and PM confirmations.
    Regards Graham V
    Full page photo (2) (5).jpg Full page photo (2) (2).jpg Full page photo (2) (4).jpg
    Full page photo (2) (3).jpg Full page photo (2).jpg Full page photo.1jpg.jpg
    Full page photo (9) (4).jpg Full page photo (2) (3).jpg Full page photo (2) (4).jpg
    Full page photo (2) (5).jpg Full page photo (5).jpg Full page photo (2) (2).jpg
    1 LH Rainwater protector NOS New item NLA item 536 853 829 03C £30.00
    1 RH Rainwater protector with all tabs £15.00
    1 Centre Rainwater protector with all tabs £20.00
    1 Right Indicator MK2 New NOS stored since 1999 Boxed £40.00 near perfect
    1 Right Indicator MK2 £20.00 has crack/marked
    1 Left Indicator MK2 £25.00 worn but no cracks
    1 RH rear Stop Lamp/Indicator Good v small crack £10.00
    1 LH rear Stop Lamp/Indicator V Good £15.00
    1 LH rear lamp tailgate V Good £10.00
    1 RH rear lamp tailgate v Good £10.00
    1 Ash tray rear New 32185796101C @£12.00
    1 Wishbone Front Lower LH VR6 £10.00
    1 Wishbone Front lower RH VR6 £10.00
    25 Wheel bolt M12 x 1.5 not vr £8.00set
    2 HUB CV Joints Re Finished £8.00 pair- heavy- postage £12
    2 Front hubs 5 stud with ABS ring working ok, were corroded now plated & rust free £10.00 pair- heavy- postage £12
    1 Servo 9" MK3? golf Golf 7:1 £10.00
    1 Clutch blue cloth covered clean feed pipe £2.00
    1 Exhaust fits after CAT VR6 MK2 1992 round-good quality £15.00
    1 Roof Gutter Rail RH edges frayed £6.00 535853706 01C
    1 Roof gutter Rail LH edges frayed £6.00 535853705 01C
    1 Roof Gutter Rail hinge cover RH £2.00ea 535853720 01C one tab broken
    1 Roof Gutter Rail hinge cover LH £2.00ea 535853719 01C one tab broken
    3 Parcel shelf black rubber hangar straps as MK2 golf £3.00ea
    1 RH & LH Drop Glass felt lined door frame seals good no tears or scrapes inner pair £30.00 outer pair £50.00
    1 LH & RH Door aperture seals good £20.00 pair
    2 Screen top cover seal £5.00each
    1 LH Outer door drop glass Slot scraper seal £18.00
    1 RH Outer door drop glass Slot scraper seal £18.00
    1 LH Inner door drop glass felt scraper seal £10.00
    1 RH Inner door drop glass felt scraper seal £10.00
    1 LH & RH Pair Door glass triangle vertical seal £10.00 pair
    1 LH Drop Glass Green tint light scratching £15.00 535845021A
    2 RH Drop Glass Green tint light scratching £15.00 535845022A
    1 Tailgate glass green tint- 2 filaments need attention £30.00 535845501A
    1 Master cyl plastic reservoir no cap NEW Non ABS £10.00
    1 Brake master cylinder ABS 23.81mm 4port NEW for Alhambra galaxy sharan but can use with mods £15.00
    2 LH door bump protector strip NEW NOS MK1 535 853 515 2BC £15.00ea
    2 LH door bump protector strip MK2 NEW 535 853 515A 2BC £46.85 sell £25.00ea
    1 LH wing bump protector freshly re textured MK2 £12.00
    1 LH door bump protector strip freshly re textured Mk2 £20.00
    1 LH rear 1/4 bump Protector freshly re textured MK2 £15.00
    1 RH rear 1/4 bump Protector freshly re textured MK2 £15.00
    1 RH wing bump protector MK2 freshly re textured £12.00
    1 Tailgate lower inner trim black all intact no clips £10.00
    1 Bonnet insulation after market thick cut waffle pattern- unused £10.00
    1 Bonnet latch Re finished £10.00
    1 Bonnet Pin Re finished £10.00
    2 Door Striker New £5.00 pair
    1 Fuel Filter clamp bracket re finished £3.00
    1 Rad top elbow @2.00
    1 First aid kit MK1 & Scirrocco NEW in soft red pouch £20.00
    1 Warning Triangle 1988-1991 £10.00
    1 Heated rear screen dash switch all good £12.00 ea
    1 Fog Lamps dash switch all good £15.00 ea
    1 Indicator stalk no hazard cowl £8.00 ea
    1 MFA Steer wheel stalk £8.00
    1 LH Mirror Casing, broken trim (also fits TVRís) @£15.00
    1 set 6 Rear bumper mount body round Clips £10.00 set
    1 set Fanfare horns rusty no bracket all ok working fine £10.00
    1 set Bumper fixing wedges £5.00
    1 set bonnet heated water jets £8.00
    2 Door check strap foam seals £1.00
    6 Fuel injectors £40.00/set of 6
    1 Plug leads set quality 8mm silicone black £15.00
    1 RH footwell airvent @£2.00
    1 Scuttle water tray seal rubber 535819521 @£5.00
    1 Tool kit strap £3.00
    1 Gear box mount selector remote plastic £5.00
    1 Gear box 1st syncro and others £5.00
    1 Power steer reservoir & cap £5.00
    Attached Images Attached Images
  2. #2
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Colchester, Essex
    Posts
    691
    I'll take the Corrado warning triangle posted please if in good condition. Please pm me your payment details. Thanks, Oli
  3. #3
    ⋆⋆ CF Donator ⋆⋆ sharpy-vr6's Avatar
    Join Date
    4th February 2012
    Location
    Southampton
    Posts
    302
    2HUB CV Joints Re Finished £8.00 pair
    Pictures are not working for me but may be interested in these how much posted?
    04 Nissan 350z (low mileage weekend fun machine)
    05 Vauxhall ashtray 1.9cdti (150bhp) my day to day smoker
    94 Corrado VR6 - Project to be tracked and enjoyed (sorry purists)
  4. #4
    Newbie
    Join Date
    16th May 2004
    Location
    west midlands
    Posts
    72
    hi buddy will take:
    1 Exhaust Sys cat backwards Powerflow £40.00
    1 Throttle Body VR6 MK3 3 pin ODB1 £20.00
    1 Bonnet insulation after market waffle pattern £15.00
    thks
  5. #5
    Regular
    Join Date
    11th October 2014
    Location
    Chippenham wilts
    Posts
    199
    Iím would like the bonnet insulation (posted) if itís in good condition/new. Same as above, canít see the pics??
  6. #6
    I would like both left and right outer slot seals please posted, 20 each
    Cheers
  7. #7
    ⋆⋆ CF Member ⋆⋆
    Join Date
    16th December 2002
    Location
    Ireland
    Posts
    868
    Hi mate, I'll take
    2 Door end bungs £4.00 pair
    1 Rear brake equalizer spring £1.00
    1 Tailgate loom rubber @£2.00
    10 Body OE aperture seals 40mm*
    £10 for the lot
    1 RH Rainwater scuttle cover no clips £5.00
    1 Fan blower motor working £5.00
    1 Rear brake equalizer bolt socket head domed £1.00
    Let me know what you need to post!
    Would also like 2nd dibbs on the Powerflow exhaust system, I was actually looking about one of these at the weekend.
    Thanks
    P.S. whats your new project?
    Satin Silver VRG
    ccgb 1667
    Quality never goes out of Style!
  8. #8
    Join Date
    3rd August 2017
    Posts
    125
    Sure its good, will check and photo later and confirm postage by PM
    Quote Originally Posted by odub View Post
  9. #9
    Join Date
    3rd August 2017
    Posts
    125
    Photos sorted now
    Post is an issue due to weight about £12 per pair =£24 sum!
    Let me know if you would like them and will then PM etc.
    Quote Originally Posted by sharpy-vr6 View Post
  10. #10
    Join Date
    3rd August 2017
    Posts
    125
    That's fine,
    Cannot do carrier on exhaust so are you OK to Collect, if so let me know and I will PM etc.
    Quote Originally Posted by g60knight View Post
    hi buddy will take:
    thks
Similar Threads
  1. Replies: 20
    Last Post: 11th May 2016, 1:42 PM
  2. Various parts clear out
    By Grrrrallye in forum Cars for Sale [Corrado]
    Last Post: 6th May 2015, 9:14 PM
  3. Having a clear out - some parts free
    By Stonejag in forum Parts for Sale
    Last Post: 30th December 2014, 1:29 AM
  4. Parts clear out.
    By Graphite in forum Parts for Sale
    Last Post: 21st June 2013, 11:58 AM
  5. Parts clear out - Mostly VR6 & R32
    By Kevin Bacon in forum Parts for Sale
    Last Post: 16th April 2013, 4:20 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupť! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
Follow us
advertising & sponsorship
