Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: Car shut down while driving, now no start.
  1. #11
    Enthusiast
    Join Date
    23rd April 2017
    Location
    Liverpool
    Posts
    326
    I had a hot start fault engine temperature sensor fault,New sensor had been fitted (by previous owner)
    Found that the wiring under the rubber boot had corroded and fell off the wiring pins,replaced the wiring and now no hot starting problem
    Also found wiring to the throttle body switch had corroded,carried wiring repair and now excellent idle hot and cold
  2. #12
    Enthusiast
    Join Date
    23rd April 2017
    Location
    Liverpool
    Posts
    326
    Carried checks on my Corrado 2.0 16 v .found the wiring under the rubber cover that goes to the temperature switch had fell off,also found the wiring to the throttle body ( 2 out of the 3 wires was snapped) repair the wiring and now starts,runs spot on.
  3. #13
    Getting frustrated with this car. Replaced the coolant temp sensor, still no luck getting it started. The battery also seems to be draining super fast.
    I assume I should be poking around with a multimeter, but where? And also, how do I check the wires for places such as the temperature sensor clip? I'm still somewhat noobie when it comes to electrical.
  4. #14
    CF-oholic! fla's Avatar
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,407
    Quote Originally Posted by Jonnom View Post
    Put a meter between the battery clamp and battery terminal and read the current. Should be around 0.2A with everything switched off.
    If its higher, pull fuses until it goes down. This will isolate your drain circuit. Then check items on that circuit.
    Hasan
    VR6 Auto to manual conversion, beige leather, aircon, TT comps, blue dash lights & switches, Koni TA/Nothelle springs, OBD2, 264 cams, Schrick
    my car
  5. #15
    When you say measuring between the clamp and terminal, which gets red and which gets black? I tried both and couldn’t get any reading besides 0. Sorry to sound so new.
    Also, on vortex, I was directed to look at the ground on the head, as looking at a diagram, it controls both the tps and clt.
    I believe this is the ground i’m looking for
    And this is the reading I got putting red to the exposed wire and black to the head
    Am I correct in assuming this ground is junk?
  6. #16
  7. #17
    When you say putting it between the clamp and terminal, how do you mean? Where do I put black and red? I tried black on terminal and red on clamp and vise versa but only got a reading of 0 each time.
    Also, on vortex I was directed to the ground at the head. This controls the coolant temp sensor among other things.
    This is what I believe to be the ground, which I found frayed and ugly looking. I put the black on the head and the red on the exposed wire on the ground, like so
    The reading indicates the ground is junk, but i’m not sure if i’m measuring it correctly
  8. #18
    Quote Originally Posted by fla View Post
    How do you mean? I tried red on terminal, black on clamp, and vise versa, but could only get a reading of 0.
    Also, on vortex, I was directed to check out the ground on the cylinder head.Attachment 91060
    I believe this is the correct ground I'm looking for. The end is all frayed and looks to be barely hanging on.
    When I attempted to read the resistance, I put red on the exposed wire and black on the head. If this is correct, it is indicating that the ground is bad. corrado2.jpg
    Is this correct? Am I measuring this correctly? And how would I repair this ground? Can I just solder on a new connection to the post?
  9. #19
    The first image got dropped.
  10. #20
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    Witheridge, Tiverton
    Posts
    5,859
    The first image, OL is open link. That means it has no reading and the circuit is open, therefore the cable is completely broken down. Check the earth necxt to the battery too. It goes to a stud right next to the battery tray just to the side. Not meaning to insult you, but when checking current, make sure the meter is set to Amps
    95 Classic Green VR - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|BBS RX228s|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
Similar Threads
  1. 2.0 16v cut and when driving and will not start.
    By viking64 in forum Engine Bay
    Last Post: 7th January 2018, 7:42 PM
  2. Door won't shut
    By howlingvr6 in forum Exterior
    Last Post: 28th May 2013, 9:05 PM
  3. So if we all start driving "Eco Cars"
    By vwdeviant in forum General Car Chat
    Last Post: 22nd July 2008, 4:30 PM
  4. Door won't shut!
    By Alexander in forum Exterior
    Last Post: 17th February 2008, 2:02 PM
  5. G-Werks Shut??
    By ghee60 in forum Suppliers Forum
    Last Post: 9th August 2005, 7:20 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
