Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: VR6 Water Cooled Oil Cooler
  1. #1
    CF Nutter GlosterOx's Avatar
    Join Date
    25th August 2008
    Location
    Gloucester
    Posts
    1,789
    My car on the motorways has, according to the MFA, an oil temperature a bit too high for my liking.
    Question is, do the coolers "clog up", as I have a spare and use of a ramp next weekend so was thinking of swapping it over as at least I can eliminate that then?
    Cheers,
    Ian.
    CCGB Membership Secretary
    ## CCGB 3243 ##
  2. #2
    Enthusiast
    Join Date
    5th December 2005
    Location
    UK
    Posts
    952
    How high we talking?
    Also didn't think the coolers ever needed replacing unless they were damaged?
    Corrado VR6 Storm
  3. #3
    Join Date
    25th August 2008
    Location
    Gloucester
    Posts
    1,789
    About 116 > 118C after a good thrash down the motorway, this was back in November with low ambient outside temperatures.
    Ian.
  4. #4
    Don't think that's unusual myself, but then mine could be clogged up too...
    It's within a couple of % of the numbers I sometimes see on long high speed runs, and these sensors are rarely more accurate than that.
    A Corrado is for life, not just for the MOT.
    [ WARNING: the above message may contain irony, sarcasm and outright lies. ]
    ** Every time you think about sex, another Corrado gets written off. **
  5. #5
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    11th March 2009
    Location
    West Midlands
    Posts
    4,229
    Quote Originally Posted by GlosterOx View Post
    Ian.
    hi ian
    i had very odd oil temp readings when my VR was in with stealth - long story short, vince checked the temps at the oil temp sensor with a laser pointer jobbie & it was consistently 6 degrees lower than the reading reported on the mfa
    i wouldnt worry with the temps you have as long as they go nicely after the thrash all should be ok i would have thought
    Kev Bacon was a bit of a whizz with temps & from memory of conversations with him im fairly sure he would agree
    however - i do know that with our VR engines specifically i had been told never to use a product like rad seal as that can end up blocking the very small channels in which the water flows for cooling
    oil cooler could be suspect but AFAIK they either work or dont, rather than gradually get worse
    Bramber metallic VR6 bring on the grins as the VR sings!!!!
    Stealth head rebuild, 263's, BMC CDA, Roose M/Sport hoses, VT engine mount, KW V1s
    KUR2Y loom, daves16v short shifter, 2.5" Longlife SS exhaust with sport cat, lots of shiny bolts & 210bhp
    Alpine White 1.8 16v, Kamei skirts, Powerflow SS exhaust, back on my drive April 2014
  6. #6
    What oil are you using? When i switched from castrol 10w-40 semi to the fuchs titan super duper stuff 10w-50 my oil temps went up abit and take longer to come back down.
  7. #7
    Join Date
    25th August 2008
    Location
    Gloucester
    Posts
    1,789
    Quote Originally Posted by gazvr6 View Post
    Exactly the same oil.
    ## CCGB 3243 ##
  8. #8
    Join Date
    25th August 2008
    Location
    Gloucester
    Posts
    1,789
    Quote Originally Posted by g0ldf1ng3r View Post
    hi ian
    Cheers,it is obviously working (and not leaking!) so will leave it for the time being. I flushed the rad/system in the summer and put new coolant mix in it so hopefully everything should be OK.
    Thanks for everyone's replies.
    Ian.
    ## CCGB 3243 ##
  9. #9
    Cheers,
    Ian.
    As others have said, for one to clog up, you'd have to be doing something really wrong I would think. That said, it is a heat exchanger, so I believe inside it the passageways are very narrow, and could be susceptible to clogging.
    I am replacing my oil cooler this week, so I'll see if a new one makes any difference to oil temps. Mine seems to be working fine but I'm replacing a cracked radiator, so am doing the oil filter housing gasket and oil cooler and its gaskets/hoses while its all in easy reach. I don't think mine is having any issues, but I'll replace it with a new Nissens one and keep the old one as a spare if it tests ok and doesn't leak.
  10. #10
    Join Date
    25th August 2008
    Location
    Gloucester
    Posts
    1,789
    Quote Originally Posted by a_riot View Post
    Be interested if it makes any difference, let me know?
    Ian.
Similar Threads
  1. Wanted: Oil Cooler Water Pipe
    By Tigerfish in forum Wanted
    Last Post: 10th August 2013, 10:25 AM
  2. VR6 Filter housing, is it water cooled!
    By ashley555 in forum Engine Bay
    Last Post: 7th March 2009, 9:06 PM
  3. Replies: 40
    Last Post: 27th July 2007, 7:43 PM
  4. Water leak from oil cooler area
    By Roger Blassberg in forum Engine Bay
    Last Post: 1st February 2006, 4:33 PM
  5. air n water cooled parts cheap as on ebay S3 TT ETC
    By hustler in forum General Car Chat
    Last Post: 3rd August 2003, 5:05 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
