Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: ABS Pump 1H2 614 217 A (VR6)
  1. #21
    Enthusiast
    Join Date
    21st August 2003
    Location
    Merseyside
    Posts
    331
    Quote Originally Posted by Dox View Post
    I've got that issue on the hard-drive - I've just watched it, they replaced the cylindrical motor for a used one, they replaced the PCB for a used one. They blew it out with an airline and blasted the corrosion from the outer casing and tested it before and after. Hardly a recon, more Franken-pump?
    Don't get me wrong I applaud them for doing their best to repair our obsolete spares and keep our cars legal, but suggest its more of a repair than a recon?
    What's the difference?
  2. #22
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,649
    Quote Originally Posted by akacheesy View Post
    We're not going to agree, so let others decide which way they want to go.
  3. #23
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,659
    Well, there aren't many options. BBA-Reman at least have diagnostics that they can use to test a pump unit. If you or someone you know is handy with electronics it's possible to take a look at the PCB yourself.
    There's very few good second hand units around because most of them weren't working when taken off the car and they were only produced for RHD in the first place.
    VW do have some new ones in stock, but at over £2k a piece I don't think there will be many takers.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  4. #24
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,649
    Quote Originally Posted by fendervg View Post
    Most Corrados have been broken because the value of there parts far exceed the prices they could achieve for the cars whole at that moment in time.
    Its not only the pumps that are unreliable, the pedal sensors are problematic too, dash lights as well as relctor rings and the wheel sensors themselves, not to mention water ingress into the ECU via a leaking windscreen. Couple that with the fact most scanners wont connect / read the codes.
    My car arrived with the light continually on, a scan with VCDS pulled loads of faults, a front wheel sensor put the light off so I could get the cars first ever MOT pass.
    The fault then went intermittent, I replaced the pump with a used one and that got rid of the inlet / outlet valve faults (after a replacement ECU had no effect what so ever) and then I had intermittent pedal sensor faults, a reconditioned (re-soldered) pedal sensor has put the light out permanently ( for the time being at least). So don't be surprised if there are multiple issues if the light has been ignored or bypassed for ever and a day.
    People have said there's just enough wiring to connect to a pump for trial without disturbing the hydraulics on the original unit, I've not tried it myself but maybe worth a go before you rip out the old unit and have the tedious job of trying to expel all the air now in the brakes lines.
    All this was before the Wheeler Dealers episode was screened with the help of this forum and its members posts.
  5. #25
    Regular
    Join Date
    2nd February 2018
    Location
    Herts
    Posts
    201
    I must admit, being a new owner, the parts situation is a bit of an eye opener as to why so many of have been broken. I had wrongly assumed the Corrado was mostly built from parts from other VW stock and didn’t realise some were bespoke.
    In terms of other pumps – I’ve seen some that look very similar but differ in the last bit of the part number - they end in 117 instead of 217. Would this work - might even be worth a punt if it’s only £30? I have seen some ending 217 B but they look like completely different units.
    1995 White VR6 CCGB Member 4303
  6. #26
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,659
    Quote Originally Posted by pfnsht View Post
    I think the 117 part is for G60s etc, with only four outlets. For a VR6 you will be looking for a six-outlet pump unit, and will also have components for EDL/EDS built in.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  7. #27
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,659
    Ah, it's a primitive system for sure - but no worse than any other of that era, and I've rarely come across a 25+ year old car with no ABS issues, if fitted. The sensors and rings are service items anyway and should be replaced regularly or when they go faulty in the case of the sensors. The pedal position sensor is a bit of a weak link, but the ABS light is a simple circuit where most often the bulb blows from having been on all the time (easily replaced) and the ECU failure due to water ingress is also pretty rare.
    One problem is that these systems don't like being sat around for long periods of time, so if a car has been off the road, there will be issues for sure, and there's also a tendency to fit cheaper after-market sensors after seeing the price of new ones from VAG.
    The later Teves 20 retrofit system is much more reliable and better designed, but they also give trouble as this age, and it's a lot of work to collect all the parts and fit for not a lot of return - but parts are easily available and an MOT pass is guaranteed! Overall braking performance is not much better though.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  8. #28
    Enthusiast
    Join Date
    4th March 2010
    Location
    Berkshire
    Posts
    600
    Checking the solenoids in the valve bank on the G60 pump is fairly easy.
    If there is sufficient interest I can post a quick how to guide?
    I've not looked at the electric motor but I guess I could include that too.
  9. #29
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    Witheridge, Tiverton
    Posts
    5,867
    Go for it, always good to share knowledge. I'm sure it doesn't differ much between them all
    95 Classic Green VR - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|BBS RX228s|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
Similar Threads
  1. URGENT Vr6 oil pump & power steering pump
    By Tony_familiaruk in forum Wanted
    Last Post: 29th December 2015, 8:09 AM
  2. Replies: 6
    Last Post: 30th May 2015, 6:18 PM
  3. Lift Pump/Fuel Pump Assembly help -
    By Moreado in forum Engine Bay
    Last Post: 25th May 2013, 1:44 PM
  4. Replies: 4
    Last Post: 8th May 2013, 8:41 PM
  5. Replies: 19
    Last Post: 5th March 2009, 10:31 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
