Results 1 to 6 of 6
Thread: Speedo not working
  1. #1
    Speedo not working
    Hi guys my speedo isn't working on my 1.8t AGU. The car was a 9a before with electronic speed sensor not the cable type. I've plugged in the gearbox connector and tried 2 different sensors and still nothing. Am I missing something? I've got code P0501/16885 and did have 00515 camshaft sensor but that has cleared and not come back.
  2. #2
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    19th January 2006
    Location
    South Manchester + Hazel Grove
    Posts
    101
    Have you tried the suggestions regarding the retrieved code?
    http://wiki.ross-tech.com/wiki/index...5/P0501/001281
  3. #3
    Well I don't know exactly where the other end of the wire goes to, ECU? In which case there's no way it's not plugged in. And I'm under the impression the ABS wheel sensor is irrelevant? The ECU gets its speed from the gearbox right?
  4. #4
    Can anyone help me with this?
    I've narrowed it down to the VSS plug not giving me 12v ignition live. 5v signal works and ground has continuity. Does anyone know where the 12v comes from (G22)?
  5. #5
    CF Nutter rado20vT's Avatar
    Join Date
    4th November 2005
    Location
    In my garage, somewhere near the top of Suffolk
    Posts
    1,084
    The 12v comes from the ignition live feed, benley shows the same feed as the ECM IGN live, its a black wire that comes from G1/4 of the fuse box (thick wire from fuse then spliced to a smaller black wire)
    For my 1.8T conversion, the signal to the gearbox sensor went direct to the cluster to drive the speedo and didnt go to the engine ECU.
    This time I have wired it so the signal T's off and also runs to the ECU (but its not running yet).
    Graham
    20v Turbo, Audi TT Leather, 17" BBS, 330mm front discs with Brembo;s, 256mm rear, Digital dash in development
    OEM++
  6. #6
    I'll check G1/4 then thanks. It's a white/black wire from the connector so does it go to ECU and then to fusebox as a solid black? I hate auto electronics
Similar Threads
  1. Speedo not working ????
    By LowDownLuke in forum Interior
    Last Post: 12th March 2010, 8:13 PM
  2. Speedo not working
    By hodgkinsons in forum Interior
    Last Post: 21st November 2006, 10:20 PM
  3. Speedo not working
    By huskerjim in forum Interior
    Last Post: 20th April 2006, 11:42 PM
  4. speedo not working
    By vr6storm in forum Archive
    Last Post: 31st August 2004, 11:08 AM
  5. speedo not working
    By boab in forum Archive
    Last Post: 15th August 2004, 9:59 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
