Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: VR6 Sounds Like a Lumpy Tractor
  1. #1
    Regular
    Join Date
    25th June 2014
    Location
    Derby
    Posts
    162
    1993 OD1 VR6
    Hey guys, so went to use the VR the other day to discover a flat battery.
    Jumped the car and got it running, but unlike normal it sounds terrible.
    Sounds like it has cams in it!!
    Feels extremely lumpy!
    Idle is stable on the Rev counter at 1k cold start and 750 warm, but sounds like a chugging or misfire, exhaust farting etc.
    Engine movement is present on idle.
    On the road it seems to pull okay maybe a little flat but with no signs of misfire/kangarooing.
    MAF has been unplugged with a noticeable change so I think that can be ruled out.
    Checked and changed the plugs, top bank looked fine bottom bank were oily.
    Leads/dizzy and rotor arm were changed a year ago.
    Anyone with suggestions Please
    Thanks
  2. #2
    CF-oholic! fla's Avatar
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,424
    Might be a blocked injector. Post up some pics of the spark plugs - this can tell a lot
    Hasan
    VR6 Auto to manual conversion, beige leather, aircon, TT comps, blue dash lights & switches, Koni TA/Nothelle springs, OBD2, 264 cams, Schrick
    my car
  3. #3
    Regular
    Join Date
    25th June 2014
    Location
    Derby
    Posts
    162
    Unfortunately I threw them away however after changing the plugs it seemed to run okay, that was yesterday now it's back again.
    The car seems fine when driving just not so great when at idle.
  4. #4
    Enthusiast Gti_Jamo's Avatar
    Join Date
    4th October 2012
    Location
    Perthshire SCOTLAND
    Posts
    581
    Have you checked the voltage at the battery? Since it was flat it could be not charging properly and the ecu is not getting 12v on idle.
    MY 1991 G60 CURRENTLY IN RESTORATION
    http://the-corrado.net/showthread.ph...-Daily-Project
  5. #5
    Regular
    Join Date
    25th June 2014
    Location
    Derby
    Posts
    162
    Interesting!
    I did check the voltage at the battery when it wouldn't start and it read around 10.5v
    I shall indeed re-check the voltage shortly.
  6. #6
    The ECU will likely have lost adaptation to your engine if it has lost power from the battery.
    Now usually, in my experience, this results in the car running smoother for a while as it will tend towards overfuelling until it adapts again but you may find issues if it's not had a clean power loss and re-apply so I would suggest doing the ECU reset process in a controlled way. That just means disconnect the battery fully for 30 seconds before reconnection. And of course you want the battery fully charged when you do this.
    Car power supply is very messy, the ECU should tolerate voltage drops as low as 8v during cranking, but if you have a flat that can't start the car at all it's possible this can cause issues for the ECU too.
    A Corrado is for life, not just for the MOT.
    [ WARNING: the above message may contain irony, sarcasm and outright lies. ]
    ** Every time you think about sex, another Corrado gets written off. **
  7. #7
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,424
    Then take it for a good drive for at least half an hour at motorway speeds. When the temps are up to normal do some hard acceleration in 2nd and 3rd.
    Hasan
    my car
  8. #8
    Regular
    Join Date
    25th June 2014
    Location
    Derby
    Posts
    162
    Hi,
    Okay so re-checked the battery and the voltage is all good.
    I decided to disconnect over night to see if it presented any remedy, unfortunately not.
    Had a spare blue coolant sensor knocking about so decided to fit that.
    Measured the pins on the current sensor and it seemed off so replaced it.
    Car is still running lumpy on idle.
    I put a cone filter on the car prior to the idle issue and all was fine but decided to re-fit the factory air box incase that was affecting the MAF, still no good.
    So to recap:
    Fresh Plugs
    Dizzy
    Rotor Arm
    Blue Coolant Switch
    MAF okay
    Engine fires immediately
    No noticeable power loss when at WOT
    RPM fluctuate slightly at idle
    Car sounds like it's chocking at idle
    At low speed and accelerating it sounds like there is resistance from the engine but above 2000rpm it pulls nicely.
    Can I achieve anything plugging in via the ODB1 ports?
    Could the ISV be causing these issues potentially.
    Much appreciated for all responses.
  9. #9
    The ECU will tell you if there is a fault, yes. That's always worth doing. Yours is a 93 with the OBD2 socket?
  10. #10
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,681
    Check for any vacuum leaks on the inlet elbow and manifold, and the PCV tubing.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
Similar Threads
  1. Replies: 0
    Last Post: 15th December 2013, 5:10 PM
  2. VR6, sounds like a tractor and knocking?
    By mikehiow in forum Engine Bay
    Last Post: 6th February 2009, 7:23 PM
  3. Tractor v Astra
    By jaded2882 in forum General Car Chat
    Last Post: 8th December 2008, 11:57 AM
  4. Tractor sound!
    By Mancorr in forum Engine Bay
    Last Post: 20th January 2007, 10:36 AM
  5. VR6 replaced head gasket. Now it sounds like a tractor
    By camper driver in forum Engine Bay
    Last Post: 18th January 2007, 12:13 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
