Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Timing Chain Symptoms
  1. #1
    Hi all,
    So far the VR has been in the garage being "fault found" for almost three weeks. We've had the Lambda replaced which hasn't solved the issue and now the garage are suggesting changing the timing chain as they consider this to be the reason for the rough running.
    Symptoms are rough idle / missfire so it sounds like a tractor and makes driving impossible.
    Thoughts on this from anyone more technical please as I didn't consider this would be the fault. Thanks
    Steve
    CCGB3401
    1994 Blackberry VR6 named Roxy!
  2. #2
    CF-oholic! fla's Avatar
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,592
    Dont think timing chains would cause rough running. Is it misfiring or running lumpy? Take the sparks out and look at their colour. Post up up some pics - will.give you a good starting point before spending loads of, perhaps unnecessary, cash!
    Also, what error codes have been shown on vcds?
    Hasan
    VR6 Auto to manual conversion, beige leather, aircon, TT comps, blue dash lights & switches, Koni TA/Nothelle springs, OBD2, 264 cams, Schrick
    my car
  3. #3
    Symptoms were refusing to idle as kept cutting out unless you kept your foot on the gas and misfiring.
    So far I've changed changed the coolant temp sensor, tried a different MAF and coilpack.
    Scanned and it initially threw a Lambda fault code which didn't come back. The usual cam position fault is the only other thing and that's been checked.
    We've drained the tank in case of off fuel which it wasn't and a new Lambda fitted.
    Cars at the garage so I can't get any pics, I'll ring them tomorrow to find what they've done comprehensively.
    Plugs and leads are certainly no more than perhaps 1500 miles old however it had been sat.
  4. #4
    ⋆⋆ CF Donator ⋆⋆ robrado974's Avatar
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,410
    What year is the car ?. As Hasan said , I agree with his comments about the chains and it will cost a lot of dough. Has the ISV been cleaned, all air pipe work vacuum hoses checked for leaks , if an early VR what condition is the dizzy in , late car coil pack .
    Edit , just reread post , you have changed the coil pack .
    92 VR6 . DBP. She will never be a show car ..... But will be up there with the best of em .
    The bmw seems invincible in isolation . But along side the corrado - a modern classic , we think- it has its work cut out . Autocar 1992.
  5. #5
    CF-oholic! sexybourbon's Avatar
    Join Date
    14th February 2010
    Location
    hull
    Posts
    3,218
    This might sound daft but check the two green nipples that are on the brake booster line on the right hand side of the engine , there down near the aux water pump area
  6. #6
    ⋆⋆ CF Donator ⋆⋆ Harrier's Avatar
    Join Date
    1st July 2008
    Location
    Hampshire
    Posts
    1,608
    The timing chain would only really be an issue if the timing has jumped a tooth or 2
    Reasonably easy to check if they know what they are doing ?
    1999-2001 91' Nugget Yellow G60
    2001-2014 94' Brilliant Black VR6
    Current - 95' Black Magic Pearl VR6
  7. #7
    Regular
    Join Date
    25th June 2014
    Location
    Derby
    Posts
    175
    I would note, mine sounded like a tractor for around 200-300 miles before eventual timing death.
    Might be unrelated but who knows.
  8. #8
    ⋆⋆ CF Member ⋆⋆ vw rule's Avatar
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,497
    Yes as above possibly vacuum leak somewhere,
    also have the fuel pressure checked just in case. Also the fuel pressure regulator when they fail, the car normally won't start up at all, but if it does it'll run like a bag of poor.
    Timing chains do stretch over time especially over 100,000 miles, the engine will sound like a bag of nails when you go on & off the throttle, on a well used warn engine like that those chains could be 1/2 a tooth or close to 3/4 of a tooth out, but for most cars it'll still run.
    But for an engine to run rough the sprockets would have to be close to 1-1/2 to 2 teeth out as mentioned above by Harrier.
    I'd firstly get the engine timed up and check everything is in alinement, because to get the timing chains replaced your looking at £1200 if not more depending who does it.
    Also get a compression test done on all six cylinders, and like I say get the fuel pressure checked.
    Crank sensor normally tells the coil pack when to fire.
    Cam sensor normally tells the injectors when to fire.
    You've mentioned that the Lambda sensor has been replaced, also the coolant temp switch, air flow sensor and coil pack.
    Could be a wiring fault somewhere or fault with the ECU, but you'd normally have a fault or error code for that.
    Si
    Had MK2 1.8 Scirocco Scarla 1998 to 2002
    had it lowered on original wheels,
    K&N air fitler and Janspeed exhaust system.
    Now have 94 M reg Corrado 2.0 16v since 2002 still got it, been off the road now since early 2015
    hoping to get it finished this year.
    Also have a 2015 Seat Ibiza TSI i-tech as my daily driver. Plus I'm on The SEAT Forum.
    Link to 16v torque settings & ECU pin locations.
    http://the-corrado.net/showthread.ph...fuel-pressures
  9. #9
    Thanks all, waiting a call back so I can ask what they've actually checked up to now.
    I'm dubious about it being the chain.
  10. #10
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,930
    Blocked cat or exhaust from remnants from the cat?
Similar Threads
  1. VR6 Timing chain Kit
    By Jim Bowen in forum Engine Bay
    Last Post: 28th March 2014, 6:37 AM
  2. where shall i buy a timing chain kit?
    By big ben in forum Suppliers Forum
    Last Post: 9th November 2009, 10:22 PM
  3. Timing chain
    By Rick_ford55 in forum Engine Bay
    Last Post: 19th October 2006, 10:42 PM
  4. Timing Chain ???
    By GinaG in forum Engine Bay
    Last Post: 22nd March 2005, 9:25 AM
  5. Timing chain
    By Baz2004 in forum Engine Bay
    Last Post: 18th March 2005, 6:12 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
