Results 1 to 9 of 9
Thread: 2.9 engine
  1. #1
    2.9 engine
    Anyone have a spare 2.9 engine that’s not been ruined cooked or flooded
  2. #2
    Can anyone help
  3. #3
    Enthusiast
    Join Date
    16th April 2006
    Location
    Bucks
    Posts
    862
    Chances are the engine you buy will be in need of an overhaul, hone, rings, bearings at a minimum... personally I would do that to my own engine.
    It surely cant be so far gone that its scrap?
    The block can be bored if the wear/rust is so far gone its past honing... cylinder heads can be devconed, skimmed and new valves - "the man in the shed" is very close to Stealth actually and he did my cylinder head as above (which had stood outside for 4 years) and ported and polished it at the same time.
  4. #4
    Cylinder head goosed and not usable block could be bored but will be a very expensive job
    Quote Originally Posted by Geeba View Post
  5. #5
    Enthusiast
    Join Date
    16th April 2006
    Location
    Bucks
    Posts
    862
    Unless that has broken into the water jacket that could be devcon'd - its only got to hold the head gasket flat - and the MLS gasket covers it - most VR6 heads will have some degree of corrosion at that exact point. mine was pitted, not to that degree but was devcon'd and skimmed, in some cases they can be welded.
    Does the block have a wear mark? rust and dirt don't matter as it will be hot tanked.
    Also not far from "the man in the shed" is "Knight Engines" they actually work together, I took my block down and Dave examined it offered to hone it and put oversized rings in, but advised larger pistons which I went for.
    Are you keeping the car?
  6. #6
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    21st December 2004
    Location
    Roma,Italy
    Posts
    2,009
    I've got a genuine 19.000km ABV bottom end mate, Send me your email and i could send you a few photos.
    cheers-Andrew
  7. #7
    ⋆⋆ CF Member ⋆⋆ Jim Bowen's Avatar
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,930
    The engine running in mine at the moment will be coming out around xmas time and I'll be wanting rid of it. Not sure how long you got.
    Runs fine but uses a bit of oil and the head is tappy. I reckon the head will need a rebuild. Was told its a 2.9 when i bought it and have a receipt from stealth that says it was a corrado engine.
    I could take the head off and measure the cylinder bores and see the general condition of it.
    Just like a golf................But better!!!
  8. #8
    Quote Originally Posted by Jim Bowen View Post
    Hoping to get this done before then but could still be interested as considering a VR6 in a Beetle Dark Flint
  9. #9
    Anyone got a full engine or even just the correct 2.9 cylinder head
    Ross
Similar Threads
  1. Engine Support Beam Versus Engine Crane
    By Erallus in forum Suppliers Forum
    Last Post: 3rd April 2018, 1:05 PM
  2. Replies: 3
    Last Post: 6th March 2011, 12:22 AM
  3. Replies: 2
    Last Post: 22nd November 2005, 7:07 PM
  4. Replies: 26
    Last Post: 21st May 2004, 9:43 AM
  5. Replies: 16
    Last Post: 14th July 2003, 11:24 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
