Results 1 to 7 of 7
Thread: Power Steering Cooling Pipe
  1. #1
    ⋆⋆ CF Member ⋆⋆
    Join Date
    14th September 2003
    Location
    County Durham, UK
    Posts
    406
    Hello. Itís been a while since I posted here, but Iíve finally started to resurrect my corrado.
    Itís a vr6 and I think I need to replace (amongst other things) the power steering cooling pipe that runs under the radiator. I can only seem to find replacements for 16v models, with part number 535 422 896A. Looking in the parts diagram though, it lists suffix B for the vr6.
    Does anybody know if the A part can be tweaked to fit a vr6, or where I can get hold of the correct part?
    Iíve tried a search on the forum, but couldnít find an answer.
    Thank you.
    Currently: '93 Dark Burgundy Pearl VR6 and '02 Saxo VTR
    Previously: '99 Saxo 1.5D X (225,000 miles!!!), '89 VW Golf MK2 GL, '90 VW Scirocco GTII, '85 VW Scirocco GT'S' (205,000 miles), '89 Austin Rover Metro GTa, '83 MG Metro 1300, '81 Austin Metro 1.0L
  2. #2
    ⋆⋆ CF Member ⋆⋆ vw rule's Avatar
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,198
    Hello there,
    below is a link to a thread that I replied to with most of the power steering pipes for a Corrado VR6
    http://the-corrado.net/showthread.ph...-Steering-Pipe
    As far as I know VW Classic Parts only list the one pipe that fits under the radiator,
    I ordered one through VW Heritage back in early July, I spoke to Ben in sales he said possibly Classic only list the one pipe in question for the Corrado.
    I bought one for my 2.0 16v
    Si
    Had MK2 Scirocco Scarla 1998 to 2002
    Now have Corrado 2.0 16v since 2002 still got it
  3. #3
    ⋆⋆ CF Member ⋆⋆
    Join Date
    14th September 2003
    Location
    County Durham, UK
    Posts
    406
    Thanks Si. Maybe there’s negligible difference between them - it’s just a bit pricey if I order one and it doesn’t fit! I guess I’ll need them to confirm first one way or the other whether it should fit.
  4. #4
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,198
    On Classic it says from 1989 to 1995
    But like you say probably best to check with one of the sales team at VW Heritage first.
    Si
  5. #5
    ⋆⋆ CF Member ⋆⋆
    Join Date
    14th September 2003
    Location
    County Durham, UK
    Posts
    406
    Just heard back from classic parts - they’ve confirmed it is a different pipe for vr6, and it’s no longer available. Oh well. Guess I’ll have to see if it can be salvaged when I remove it. Hopefully it just looks a lot worse than it really is, otherwise I’ll have to improvise something.
  6. #6
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,198
    I presume there the same diameter of pipe between the 4 cyl and VR6 Corrado's,
    is it just then the angle at which they bend under the radiator differs slightly, or are the two fixing brackets attached to the VR6 pipe wider a part compared to that of the 4 cyl one ?
    Si
  7. #7
    ⋆⋆ CF Member ⋆⋆
    Join Date
    14th September 2003
    Location
    County Durham, UK
    Posts
    406
    Without a 16v pipe (or at least the measurements) to compare with I’m not sure how different they are. However, I’ve now got the pipe off and it doesn’t look quite as bad as I’d feared so I’m hopefully I can clean it up (without it going into holes) and repaint it. Fingers crossed!
Similar Threads
  1. VR6 Power Steering Pipe
    By tonedef in forum Wanted
    Last Post: 25th June 2018, 5:12 PM
  2. Power steering pipe?
    By Bfstrachan in forum Engine Bay
    Last Post: 26th November 2015, 9:16 PM
  3. Power steering pipe
    By Corradochris16v in forum Wanted
    Last Post: 20th July 2012, 10:41 PM
  4. Power steering pipe
    By Wild-Animal in forum Wanted
    Last Post: 23rd January 2012, 9:16 PM
  5. Power steering cooling pipe removal tips
    By KIPVW in forum Engine Bay
    Last Post: 20th February 2011, 5:55 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupť! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
Follow us
advertising & sponsorship
