Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: Front wheel bearing housings
  1. #11
    ⋆⋆ CF Member ⋆⋆ vw rule's Avatar
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,259
    Also I've had a similar issue with the centre hub that's part of the rear brake discs,
    a new bearing I was fitting to the rear disc's, again it felt loose so had to purchase a new set of rear disc's, so possibly the rear hubs are similar in that you're only able to punch / press them in 2 to 3 times max ??
    Si
    Had MK2 1.8 Scirocco Scarla 1998 to 2002
    had it lowered on original wheels,
    K&N air fitler and Janspeed exhaust system.
    Now have 94 M reg Corrado 2.0 16v since 2002 still got it,
    been off the road now since early 2015
    hoping to get it finished this year.
    Also have a 2015 Seat Ibiza TSI i-tech as my daily driver.
  2. #12
    ⋆⋆ CF Member ⋆⋆ Jim Bowen's Avatar
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,960
    Won't the bearing expand as it heats up. Can't say I've encountered this issue and my hubs are the 230,000mile originals
    Just like a golf................But better!!!
  3. #13
    ⋆⋆ CF Donator ⋆⋆ robrado974's Avatar
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,332
    I guess I was lucky with mine then . Mine are on 155k . I suppose the inside bore can get worn ?. It’s a lot of dough for a new pair .
    92 VR6 . DBP. She will never be a show car ..... But will be up there with the best of em .
    The bmw seems invincible in isolation . But along side the corrado - a modern classic , we think- it has its work cut out . Autocar 1992.
  4. #14
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,848
    I pressed a new bearing in my NSF, no issues, 95Kish miles, but it was an OE bearing.
    With nothing moving inside the actual housing I cant see how it can wear?
    Undersized bearings would be my guess
  5. #15
    Quote Originally Posted by robrado974 View Post
    My theory is that large, heavy wheels with incorrect offsets, combined with low suspension and excess camber can cause an issue with the wheel bearing housings where a tiny bit of play can develop between the bearing and the housing. My first Corrado had a very strange issue when I bought it where backing up and turning would cause a loud "crack" sound from both sides of the front of the car, almost like a gun shot. I could feel the vibration in my feet, and it had a slight springy sound as well, so I figured it was a loose suspension component, vibrating the spring.
    But replacing all that made no difference. It was a difficult problem to diagnose, since it was such a weird, unnatural problem that you likely would never see but for lowered vehicles with oversized wheels, which mine had when I got it. I got rid of those wheels, and put a normal suspension in the car, and swapped the housings for a pair of used Passat housings I found, and this instantly cured the problem. I think a lot of people make dumb modifications that result in bizarre failures you won't ever see otherwise, and these can be very difficult to diagnose, like worn/warped wheel bearing housing bores.
  6. #16
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,960
    Can they be tapped in with a hammer? I have some new housing and bearings and not gotten round to taking them to a garage to get them pressed in. Would rather do it myself though
  7. #17
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,848
    Quote Originally Posted by Jim Bowen View Post
    Its a bit "bush fix". Presses are cheap if you have room? My floor standing 20T was £90 delivered to my door.
  8. #18
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,960
    I've run out of room, got 4 vr lumps in the garage at the moment ��
  9. #19
    You could with a hammer and appropriately sized socket or cup. Some people freeze the bearing to make it a bit easier to install. I'd rather press them in though, as hammering on round things tends to make them less round.
  10. #20
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,259
    Quote Originally Posted by a_riot View Post
    Yeah as above it's better using a 10 tone or 15 tone press when fitting the cartridge type bearings, as using a hammer and socket can damage the seals, and there's a small risk of creating fine metal filings which could possibly get into bearing if the seal is damaged.
    Si
Similar Threads
  1. Best front wheel bearing
    By Jon_vr6 in forum Drivetrain
    Last Post: 21st July 2017, 6:40 PM
  2. Front wheel bearing growler
    By Atki in forum Drivetrain
    Last Post: 14th January 2011, 1:14 PM
  3. how do you replace a front wheel bearing
    By marf497 in forum Drivetrain
    Last Post: 1st February 2010, 5:55 PM
  4. Front wheel bearing
    By 4stud in forum Drivetrain
    Last Post: 16th March 2009, 5:13 PM
  5. Front Wheel Bearing
    By joeshenton in forum Drivetrain
    Last Post: 11th November 2008, 1:34 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
