Results 1 to 6 of 6
Thread: Headlights still poor
  1. #1
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,144
    Ive just drove the corrado in the dark 1st time this year.i cant believe how crap the lights are with loom upgrade and philips 150% racing bulbs.anything new about to upgrade them
    1990 1.8 16v white
  2. #2
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,676
    If your reflectors are corroded this might reduce the light output - also check the upgraded loom connectors and the battery terminals it connects to for corrosion. An easy check is also to check for voltage at the connector at the headlight - see what you're getting there.
    These lights are also sensitive to correct alignment, and even a slight error there can put the beam in the wrong place and reduce visibility. It will never compare to a modern car, but with the upgrades you've mentioned it should be quite acceptable and safe.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  3. #3
    The lights are fading these days. After 20+ years the silvering goes hazy and in some cases it's just come off. They don't put out as much light as they used to. Mine has been flagged up on the mot for about five years in a row...
    [ WARNING: the above message may contain irony, sarcasm and outright lies. ]
    ** Every time you think about sex, another Corrado gets written off. **
  4. #4
    Anyone got any ideas where to get a headlight adjuster for a Corrado headlamp ... ?? Seems like a good job for a 3D printer for the small plastic component that collapses when you touch it when you're trying to refurbish them ..
  5. #5
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,676
    Used to be available online from a few places - maybe try Arz-Tuning - I think they used to have them?
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  6. #6
    Nope, I've only seen the small plastic end piece that clips into the back of the reflector. The bit that disintegrates is the plastic grommet that holds the adjuster screw in the back of the headlight housing itself. That bit I've not been able to find anywhere.
Similar Threads
  1. Poor service from INPRO headlights
    By robmajestix in forum Suppliers Forum
    Last Post: 24th October 2009, 6:36 PM
  2. headlights poor.
    By ian... in forum Exterior
    Last Post: 27th September 2008, 4:12 PM
  3. headlights poor
    By taffyjenks in forum Exterior
    Last Post: 1st February 2008, 10:19 PM
  4. Poor Headlights II
    By Just 1.8 16V in forum Exterior
    Last Post: 11th January 2005, 5:46 PM
  5. Very Poor headlights
    By PhatVR6 in forum Archive
    Last Post: 12th December 2003, 12:45 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
