Results 1 to 6 of 6
Thread: Shifter question
  1. #1
    Newbie
    Join Date
    21st September 2018
    Location
    Reno, Nevada
    Posts
    47
    Shifter question
    I have a question about the shifter in my car. I have a 1990 g60 and recently had the transmission and shifter cables replaced. Since that happened I now have to push down and left for reverse AND first. Is this something normal? Or should I replace the shifter cables again?
    Thank you!
  2. #2
    CF-oholic! fla's Avatar
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,459
    Might need adjustment at the gearbox end. Just check the bolts are not loose. In neutral the selector tower on the box should not have moved.
    Actually, first check the small circlip on the gearstick is still in place!
    Hasan
    VR6 Auto to manual conversion, beige leather, aircon, TT comps, blue dash lights & switches, Koni TA/Nothelle springs, OBD2, 264 cams, Schrick
    my car
  3. #3
    Newbie
    Join Date
    21st September 2018
    Location
    Reno, Nevada
    Posts
    47
    I also have to go down and to the right for second. Could making those adjustments explain that as well?
  4. #4
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,459
    might be. Check for the circlip first and whilst you're there just see if there isn't any excessive play in the plastic pivot that the circlip sits in. It may be that you need a spacer washer to tighten it up a bit.
    There is a guide on here somewhere - its quite straightforward to do and i'll see if i can dig it out, unless someone can post it first. Dox is one of the masters of finding lost threads!
    Hasan
    my car
  5. #5
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,459
    Hasan
    my car
  6. #6
    Newbie
    Join Date
    21st September 2018
    Location
    Reno, Nevada
    Posts
    47
    Much appreciated!
Similar Threads
  1. MK4/Polo Shifter
    By Wompa in forum Drivetrain
    Last Post: 2 Weeks Ago, 9:52 PM
  2. VWMS shifter cable question
    By D-13 in forum Drivetrain
    Last Post: 26th January 2015, 8:49 PM
  3. B & M shifter for 16v
    By corradlo in forum Wanted
    Last Post: 26th January 2013, 10:02 AM
  4. mk4 shifter fit ctn box?
    By falcodub in forum Drivetrain
    Last Post: 12th October 2009, 5:41 PM
  5. B & M short shifter
    By iflorey in forum Drivetrain
    Last Post: 19th February 2006, 10:22 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
