Results 1 to 5 of 5
Thread: Fuel pump buying advice.
  1. #1
    ⋆⋆ CF Donator ⋆⋆ robrado974's Avatar
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,330
    I’m experiencing some spluttering problems at the moment with the VR. I’m not suggesting it is the fuel pump at this stage , I’m just enquiring on which one anyone has bought. Obviously I would stay away from the cheapies on eBay . The Bosch one looks ok . I’ve got a second hand later pump in the car at the moment, so no worries about swapping the float ( 92 pumps had a different float ). Any suggestions are appreciated.
    Rob
    92 VR6 . DBP. She will never be a show car ..... But will be up there with the best of em .
    The bmw seems invincible in isolation . But along side the corrado - a modern classic , we think- it has its work cut out . Autocar 1992.
  2. #2
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,932
    Bosch, Siemens\VDO or Pierburg - all the other ones are rubbish.
    Sometimes you can get just the pump motor insert rather than having to replace the whole unit. Did you test the fuel pressure with a gauge connected to the fuel rail? I'd check the filter, FPR and injectors first.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  3. #3
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,330
    Hi Fender.The FPR was changed a few years back . I’ve changed the fuel filter this evening. Thanks for the pump info .
  4. #4
    ⋆⋆ CF Donator ⋆⋆ tonedef's Avatar
    Join Date
    4th October 2006
    Location
    Cuckney
    Posts
    993
    Bosch pump from ECP, fitted a couple of years ago and seems to be working fine. I must have upset the sender for the gauge when I fitted it though as it takes days for it to work it’s way up after filling. Job on the list for this winter!
    95 Classic Green VR6: Climatronic & OBD2, Grey Leather Recaro Interior
    CCGB No. 058
  5. #5
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,330
    I’m not sure what’s happened to your sender tone . It just slides on from memory?.
Similar Threads
  1. Fuel pump problems ? advice needed please .
    By robrado974 in forum Engine Bay
    Last Post: 2nd July 2013, 6:35 PM
  2. VR6 fuel pump advice needed!
    By carter711 in forum Engine Bay
    Last Post: 10th June 2012, 9:14 PM
  3. Noisy relay 67/167 and fuel pump advice
    By James. in forum Engine Bay
    Last Post: 31st October 2009, 4:12 PM
  4. 2.0L 16V, fuel pump problem,advice needed.
    By BigIainy in forum Engine Bay
    Last Post: 24th June 2008, 8:39 PM
  5. Corrado 16v fuel pump and Golf Mk2 16v fuel pump....
    By alackofspeed2 in forum Engine Bay
    Last Post: 21st March 2006, 6:15 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
