Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Torpan Sump Pan
  1. #11
    ⋆⋆ CF Donator ⋆⋆ robrado974's Avatar
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,196
    I can’t remember which one I bought . It may have come from Heritage or Ebay ?. As said I don’t think there’s anything in it with a part like this . I would recommend getting the rubber/cork type washer for the sump plug , mine came with a metal one which did not seal well at all .i nipped it up but I still had a drip , so I changed it .
    92 VR6 . DBP. She will never be a show car ..... But will be up there with the best of em .
    The bmw seems invincible in isolation . But along side the corrado - a modern classic , we think- it has its work cut out . Autocar 1992.
  2. #12
    ⋆⋆ CF Member ⋆⋆ Jim Bowen's Avatar
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,949
    That new engine i bought, (Meant to have come from VW), had no gasket on the sump, just quite a thick layer of white sealant.
    Just like a golf................But better!!!
  3. #13
    CF-oholic! delfinis38's Avatar
    Join Date
    24th February 2006
    Location
    Muckle Flugga & Fastnet Rock
    Posts
    3,359
    Does the later gasket need sealant ?
    Corrado VR6 - Aqua Blue LC5U - 96 'N' Plate
    Black Leather - Heated Seats - Air Con
    Totally Standard and intend to keep it that way !
    Hibernation for Winter ! SORN
  4. #14
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,695
    I have a 4motion MK4 sump ready to use when needed, being cast alloy the flange doesn't distort like a steel sump when you tighten the bolts up into the gasket. Put a straight edge across the row of bolt holes on your old or replacement steel sump too see how distorted they are and the likelihood of seepage.
  5. #15
    Join Date
    24th February 2006
    Location
    Posts
    3,359
    Done exactly that at lunch... put a steel rule over the mating surface that gasket sits on and tried to see light through the gap... all seems good here. It has a graze on the flat area by the sump bolton the outer skin assume it's not too thin material here.
    Thanks dox
  6. #16
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,196
    Quote Originally Posted by delfinis38 View Post
    Later cars had longer bolts and a rubber seal I believe. Mine is a 92, so I have a the thin paper type gasket so I put a smear around the surface first .
Similar Threads
  1. New VR sump pan
    By delfinis38 in forum Engine Bay
    Last Post: 21st May 2014, 8:35 PM
  2. changing back to a VR6 sump from an R32 sump
    By Danny Ess in forum Engine Bay
    Last Post: 12th February 2014, 10:04 PM
  3. Vr6 Sump 2.8 vs 2.9
    By Madjackal in forum Engine Bay
    Last Post: 20th July 2012, 3:04 PM
  4. Sump
    By jinx in forum Engine Bay
    Last Post: 7th July 2006, 11:27 AM
  5. Oil sump for Vr6 but where and which ?
    By Jay_vr6 in forum Engine Bay
    Last Post: 17th September 2005, 6:05 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
