Results 1 to 9 of 9
Thread: Kr 16v Corrado power steering fluid ?
  1. #1
    Newbie
    Join Date
    23rd March 2018
    Location
    Co.Roscommon. Ireland.
    Posts
    30
    Hi ,
    What is the correct power steering fluid for an early 1990 16v corrado?
    I have done numerous searches on here and elsewhere and I'm no clearer on it at all ,more confused than ever ...
    Firstly my reservoir is the old rectangular type and has a red cap which would indicate ATF,
    ATF is even wrote on top of the res as well.
    I've drained out the old fluid and it was so dirty it was difficult to tell if it was green or red origionally but I would have said green if pressed on it.
    I've read online that all corrado,s regardless of age use the green fluid, I've a mk2 golf Haynes manual which says that from April 1989 vw switched from red atf to the green stuff , Golf info I know but essentially the same pump and rack for the time.i had an 91 mk2 a few years back and I used the green fluid and had no problems btw.
    I have a late 91 build g60 as well,it also has a red cap on the reservoir but it looks like green fluid within .
    Yours confused ???
  2. #2
    ⋆⋆ CF Donator ⋆⋆ Bauhaus's Avatar
    Join Date
    5th July 2004
    Location
    South East Essex
    Posts
    159
    Power steering fluid
    I use this in my late 91 Corrado, and have also used the same fluid in my 88 MK2 Golf (after full flushing)with no problems.
    Attached Images Attached Images
  3. #3
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,181
    I put chf in mine the green stuff
    1990 1.8 16v white
  4. #4
    Regular
    Join Date
    15th October 2008
    Location
    West Yorkshire
    Posts
    246
    I use this stuff in all my Mk2 and Mk3 Golfs and it will be going in my 1992 G60 Rado too (if I ever get it back on the road!)
    As mentioned above, flush all the old out when you do it.
    https://www.vwspares.co.uk/product_i...roducts_id=172
  5. #5
    Newbie
    Join Date
    23rd March 2018
    Location
    Posts
    30
    Quote Originally Posted by Simeon View Post
    Thanks for replies so far.
    I have a bottle of the Febi fluid that I used to use in the mk2 golf gti I had . It was in a white bottle though. Like this.https://www.europaparts.com/power-st...-bilstein.html
    Think the only difference is one is mineral based and the green is sythentic based .
    I'm going to go into vw and see what they say on it!
  6. #6
    Newbie
    Join Date
    23rd March 2018
    Location
    Posts
    30
    Called into the vw dealer this evening .
    This fluid is listed for all corrado models so I guess that is that!
    Well it was until the parts manager happened to walk buy as I was buying it and insisted it was the wrong stuff for my car!!
  7. #7
    thats the fluid my local vw dealer sold me for both my mk2 16v and my g60 - no problems to date!
  8. #8
    Join Date
    5th July 2004
    Location
    South East Essex
    Posts
    159
    Quote Originally Posted by Brian1975 View Post
    That's the correct stuff, its the same as mine, except the code on mine is G 002 000.
    Unless the parts manager at your stealer has been working for VW for at lest 25 years take his advice with a pinch of salt, he will probably be only be up to speed with cars from the last 10 years
  9. #9
    Newbie
    Join Date
    23rd March 2018
    Location
    Posts
    30
    According to ekta G004 000M2 supersedes the G002 000 code but is the same.
    I'm going to use this ,I got a second bottle so I have enough to give the pump and rack a good flush out so hopefully all will be ok.
Similar Threads
  1. What VW power steering fluid?
    By Redfox in forum Engine Bay
    Last Post: 21st March 2012, 6:31 AM
  2. Power steering fluid
    By rajarella in forum Suppliers Forum
    Last Post: 3rd September 2009, 1:12 PM
  3. Power steering fluid?
    By Valver in forum Drivetrain
    Last Post: 14th May 2008, 10:14 PM
  4. Power Steering Fluid
    By stingman123 in forum Drivetrain
    Last Post: 9th June 2006, 12:45 PM
  5. power steering fluid
    By APJ in forum Engine Bay
    Last Post: 28th May 2004, 2:09 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
