Results 1 to 6 of 6
Thread: Last resort for poor idle .
  1. #1
    ⋆⋆ CF Donator ⋆⋆ robrado974's Avatar
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,089
    I suppose now I need a vagcom , as I’m out of ideas .
    The ISV has been cleaned.
    The ISV has been changed.
    I’ve had all the vac hoses off and there are no splits.
    I’ve cleaned the plugs to the vac lines .
    The MAF has been pulled whilst the engine is running and the note changes and it starts to stall.
    I also experienced a loss of throttle / power which I think was fuel related.
    I’ve fitted a new fuel filter. Obviously the new filter was dry and it took two turns of the key to fire, I would think this rules out the pump , if it was on its way out it should have struggled I would of thought.
    The FPR is only a few years old too.
    The plugs have only done 1500 miles or so .
    The ignition leads are 1500 miles too.
    Dizzy is fine and the rotor arm .
    I’ve cleaned the throttle body too, ok so it was still on the car but ive opened the butterfly and got in as far as I could.
    So I think the only option is now a vagcom check .
    92 VR6 . DBP. She will never be a show car ..... But will be up there with the best of em .
    The bmw seems invincible in isolation . But along side the corrado - a modern classic , we think- it has its work cut out . Autocar 1992.
  2. #2
    ⋆⋆ CF Member ⋆⋆ Jim Bowen's Avatar
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,926
    Vagcom would be a good idea, might give a suggestion of where to look.
    Just like a golf................But better!!!
  3. #3
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,089
    I think I will be clutching at straws otherwise Jim . I could spend hundreds replacing parts I don’t need until I found the problem.
  4. #4
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,089
    I’ve had another check this weekend.
    I knew it wouldn’t help but it can’t help to try .
    I sprayed easy start to check for vac leaks again .
    The coil has been changed.
    I’ve fitted new plugs .
    I’ve removed the BMC , just in case it was dirty and playing the MAF up.
    I’ve unplugged the ISV , whilst the car is running and it made a difference so it’s working,I then fitted another working ISV , just in case .
    Result . It’s still the same sketchy idle .
  5. #5
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,926
    Is it just the idle? Does it run ok apart from that?
  6. #6
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,089
    Yes jim . Pulls like a train . Maybe I have narrowed it down to the potentiometer?. I’ve checked the wires to the electrical plugs too. They are wrapped well and no amount of wiggling alters anything.
Similar Threads
  1. Poor idle , now spluttering .
    By robrado974 in forum Engine Bay
    Last Post: 2 Weeks Ago, 7:31 PM
  2. Poor idle and I've done everything! VR6
    By John Blount in forum Engine Bay
    Last Post: 19th November 2017, 3:05 PM
  3. poor idle
    By darren16v in forum Engine Bay
    Last Post: 11th May 2010, 7:45 PM
  4. poor idle spped
    By dannyc in forum Engine Bay
    Last Post: 4th May 2006, 9:06 PM
  5. poor idle
    By Bean in forum Archive
    Last Post: 27th January 2004, 8:50 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
