Results 1 to 5 of 5
Thread: Headlight Low Beam Problem
  1. #1
    Hi, I've got an issue with my G60 Corrado's headlights, the low beams specifically. Whenever the car is on, my right low beam is automatically on but my left won't turn on at all. Brights and driving lights work just fine. I don't know much about the headlights on these cars, but I had them fixed for just a night and I'm not sure what went wrong again. Thanks in advance.
  2. #2
    It doesn't seem to be quite the same each time either, originally the low beams were just always on if the car was on. After we thought it was fixed, they worked correctly but only one would come on. Now one is always on if the car is on, and the other just won't work. This car was previously owned by someone who really messed up the wiring, but I'm really not sure if this was something they did.
  3. #3
    ⋆⋆ CF Member ⋆⋆ Jim Bowen's Avatar
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,960
    I had similar issues and turned out to be the stalk on steering wheel. Think something broke down inside it and was sending mixed signals
    Just like a golf................But better!!!
  4. #4
    Enthusiast
    Join Date
    23rd April 2017
    Location
    Liverpool
    Posts
    350
    Possibly a earth fault,run a separate earth on that side
  5. #5
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,726
    Is there an aftermarket loom fitted for the lights? Worth checking. Also the headlight switch and the stalk contacts as mentioned above. You might need to get someone to hold a test light or multimeter on the headlight plugs and and then work through all the components.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
Similar Threads
  1. Full Beam Headlight Problem
    By anubis in forum Exterior
    Last Post: 1st March 2015, 7:56 PM
  2. Headlight Beam Adjusters
    By Talltorrac in forum Wanted
    Last Post: 21st November 2013, 1:08 PM
  3. main beam headlight fuse keeps blowing
    By stevej in forum Exterior
    Last Post: 8th December 2007, 12:39 AM
  4. Headlight beam too high
    By Stan 24v in forum Exterior
    Last Post: 31st October 2005, 9:25 AM
  5. Bad Beam Pattern on New Headlight!
    By designrob in forum Exterior
    Last Post: 26th September 2005, 11:18 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
