Results 1 to 5 of 5
Thread: Best Zinc Primer Spray?
  1. #1
    Anyone got an idea of the best zinc primer spray to stop rust coming back
  2. #2
    Enthusiast
    Join Date
    16th April 2006
    Location
    Bucks
    Posts
    910
    I used UPOL Zinc 182 - but I did remove the rust first with hydrochloric acid - if you intend to paint with 2-pack paint go easy on the panel wipe as it will remove aerosol type primer, but the primer itself is completely stable under the paint.
    The rust has not returned on anything I've done (mostly battery tray) so far.
    Really unless you remove it..... it will come back... my experience with remedies and potions is bad, - cut it out, shot blast it or acid removal has had the best results for me, then a good coat of primer.
  3. #3
    It’s a back wheel arch of a car not my Corrado but another car and it will be painted by a body shop so difficult to shot blast.
    It’s surface rust and has been ground out
    Ross
  4. #4
    Enthusiast
    Join Date
    16th April 2006
    Location
    Bucks
    Posts
    910
    A bodyshop should have a sandblaster that has a direct panel rubber gaiter fitted to it so it can be held directly on the panel, it also has a vacuum cylinder that pulls the used sand away..
    Something like this...
    https://www.ebay.com/itm/28-Gallon-A...-/362459652321
    I used to use it all the time when I worked in a bodyshop for mainly getting the rust out of wheel arches! usually MK3 Escort XR3i's - rot boxes they were! LOL!
  5. #5
    ⋆⋆ CF Member ⋆⋆ Jim Bowen's Avatar
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,960
    Just like a golf................But better!!!
Similar Threads
  1. Zinc plating
    By Macdaddy in forum Engine Bay
    Last Post: 22nd February 2015, 2:26 PM
  2. Best Primer?
    By NewbridgeJob in forum Exterior
    Last Post: 1st March 2012, 9:57 PM
  3. Acid etched or zinc primer?
    By G60BoyRacer in forum Exterior
    Last Post: 25th July 2009, 8:27 PM
  4. make-shift spray booth, NOW WITH SpRAY GUN!
    By -Neil- in forum General Car Chat
    Last Post: 23rd February 2006, 8:46 AM
  5. rear lenses: to spray or not to spray?
    By timatsorted in forum Exterior
    Last Post: 12th July 2004, 7:57 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
