Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Uprated loom fuse melted!
  1. #11
    CF-oholic! delfinis38's Avatar
    Join Date
    24th February 2006
    Location
    Muckle Flugga & Fastnet Rock
    Posts
    3,349
    rob ive wrapped my bank of fuses in self amalgamating tape not ideal but it seals them.....
    Corrado VR6 - Aqua Blue LC5U - 96 'N' Plate
    Black Leather - Heated Seats - Air Con
    Totally Standard and intend to keep it that way !
    Hibernation for Winter ! SORN
  2. #12
    ⋆⋆ CF Donator ⋆⋆ robrado974's Avatar
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,170
    Hi Delfinis . I will get some tape . Still need to keep the relays out of harms way though .
    92 VR6 . DBP. She will never be a show car ..... But will be up there with the best of em .
    The bmw seems invincible in isolation . But along side the corrado - a modern classic , we think- it has its work cut out . Autocar 1992.
  3. #13
    CF-oholic! fla's Avatar
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,418
    Rob mine are in a box. Nice and dry but the fuses are exposed. They're the splashproof ones but even these got moisture in them.
    I've replaced the failed fuse holder but will cover it with some grease to keep it waterproof. Some silicone grease will be fine. I'll post up some pics shortly including the burnt fuse holder
    Hasan
    VR6 Auto to manual conversion, beige leather, aircon, TT comps, blue dash lights & switches, Koni TA/Nothelle springs, OBD2, 264 cams, Schrick
    my car
  4. #14
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,170
    What sort of box are you using Hasan ?. My fuses seem to be stuck in the air so I don’t have a problem with them .
  5. #15
    Enthusiast Gti_Jamo's Avatar
    Join Date
    4th October 2012
    Location
    Perthshire SCOTLAND
    Posts
    581
    I'm using an small household electrical junction box for my relays and fuses. Mounted on the inner wing next to the battery.
    MY 1991 G60 CURRENTLY IN RESTORATION
    http://the-corrado.net/showthread.ph...-Daily-Project
  6. #16
    Where is the best place to get an Uprated loom
  7. #17
    ⋆⋆ CF Donator ⋆⋆ Bauhaus's Avatar
    Join Date
    5th July 2004
    Location
    South East Essex
    Posts
    125
    Quote Originally Posted by jared_nomak View Post
    I believe someone on here was producing the three relay version for the corrado... I think his name on here is Kur2y
    The idea for using three relays is one relay is for the dip and the other two are for the off side and near side main beams, if one of the main beam relays or its fuse fails you still have the other one to light the way home.
    The more common two relay loom is just a cut down version and if your main beam relay or fuse fails on the move your buggered.
    Both loom versions work but its down to personal choice at the end of the day.
  8. #18
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,675
    If you keep your original connectors to switch the relay it's also simple to re-connect the original loom if anything fails on the new one in an emergency.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  9. #19
    Join Date
    5th July 2004
    Location
    South East Essex
    Posts
    125
    Quote Originally Posted by fendervg View Post
    True, But my point is.. if like me you live in a rural area with unlit roads with plenty of bends and if both your main beams go in the dark its a bad situation when on the move.. better to have the safety margin of a three relay loom, but yes always keep your original loom and connectors intact.
Similar Threads
  1. Replies: 10
    Last Post: 19th August 2012, 1:38 PM
  2. uprated loom
    By carrots in forum Exterior
    Last Post: 13th July 2010, 5:14 PM
  3. Which Uprated Loom?
    By Owen VR6 in forum Exterior
    Last Post: 18th November 2008, 1:50 PM
  4. Replies: 4
    Last Post: 14th April 2005, 7:10 PM
  5. Uprated Loom
    By 146 Jockey in forum Engine Bay
    Last Post: 9th December 2003, 3:05 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
