Results 1 to 5 of 5
Thread: Passenger front brake sticking on. Please help
  1. #1
    Hi guys. I have a problem that my passenger front brake is stuck on without retracting when the brake pedal is released. The drivers is doing it a little but not as much as the passenger. It is pretty much solid. I know the calipers are fine. Rears are free. I have checked them and the sliders are all greased and doing there job properly. I have new copper lines throughout and new braided hoses. The car was originally a KR but now is a 1.8T. I bought the car with a dead engine. I have fitted 280mm discs with girling calipers and ebc green stuff pads.
    The rears are all new with a polo gti hub conversion with mk4 rear calipers.
    The only thing that is not new are the master, servo and brake proportioning valve.
    Has anyone had a similar snag? The front brakes are new and fully greased and sliding how they should. I am literally pulling my hair out now.
    Any help would be great.
    Thanks in advance.
    Rich
  2. #2
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,717
    To see if the hydraulics are holding the brakes on undo the nipples on each caliper in turn, if it spurts and the brake releases you have an hydraulic issue
  3. #3
    Thanks for your quick reply. I will do that tomorrow. Do you think the proportioning valve would cause an issue or if the rigid lines were incorrectly installed in the wrong ports on the valve?
    I could with a drawing or diagram just to double check its done correctly.
  4. #4
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,717
    Quote Originally Posted by Dubstar81 View Post
    The LPV just reduces pressure to the rear, your issue is the front
  5. #5
    Regular
    Join Date
    15th October 2008
    Location
    West Yorkshire
    Posts
    215
    Did you remove the pistons from the front calipers prior to fitting them to check condition / replace seals?
    If not I expect they need replacing, only about £25 for a kit from BiggRed and a couple of hours to remove, replace, refit
Similar Threads
  1. Front brakes sticking on
    By TimJ in forum Drivetrain
    Last Post: 1st June 2012, 11:13 AM
  2. Front brakes sticking
    By corradoloon in forum Drivetrain
    Last Post: 20th May 2011, 5:24 PM
  3. Sticking Brake
    By plummer in forum Drivetrain
    Last Post: 24th May 2010, 7:42 AM
  4. Front right brake sticking
    By belfastfumanchu in forum Drivetrain
    Last Post: 30th January 2005, 10:33 PM
  5. Passenger window sticking??
    By Bally in forum Archive
    Last Post: 13th October 2003, 9:33 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
