Results 1 to 6 of 6
Thread: Front floor/ jacking point repair section from Heritage
  1. #1
    CF Nutter
    Join Date
    19th May 2004
    Location
    St.Albans
    Posts
    1,451
    Can anyone advise if the front jacking point repair section available for Golf Mk 2 on VW HERITAGE is useful, either with or without fettling, in sorting out the badly corroded section on my 1994 Corrado VR6?
    Alternatively can anyone give general advice on fabricating a repair, maybe using a section from a scrapped vehicle?
    Best wishes
    RB
  2. #2
    ⋆⋆ CF Member ⋆⋆ vw rule's Avatar
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,198
    Hello there,
    I believe our Corrado's were made based from the MK2 Golf floor pan, so some or most of the replacement floor panels or repair floor panel sections will fit our Corrado's, with possibly very slight fabrication needed to make them fit right.
    Part number 191 803 203
    Front left floor repair panel (quarter front section) = for Corrado / MK2 Golf 1984 to 1995
    Part number 191 803 204
    Front right floor repair panel (quarter front section) = for Corrado / MK2 Golf 1984 to 1995
    Regarding the MK2 Golf jacking point repair panel, in my opinion it'll need some fabrication to make it fit correctly, as these are individually visible each side on the Golf, where as on our Corrado's it's more of a reinforced panel welded to the front chassis, then moulded / welded at the base to the front inner wheel arch.
    It's more of a reinforced box section on our Corrado's, but on the MK2 Golf like I say it's a stand alone jacking point piece.
    You possibly could use the MK2 Golf ones but you'll have to fabricate the reinforced triangular box section around / over it,
    plus you'll probably need to weld in the repair floor section at the front also.
    The jacking point panel is something like 3mm to 4mm think, it has to be fairly robust as it's where the Corrado is jacked up.
    You'll need a ruler or taper measure.
    You'll need steel sheets to fabricate the triangular box section.
    Disconnect car battery.
    Pull up carpet / sound proving membrane on drivers side.
    Move any wiring loom in that area.
    A welder and all the other gear.
    A spot weld drill bit and drill.
    Hammer / chisel / safety specs.
    Grinder with cutting disc and grinding disc.
    A bottle of rust eater / converter.
    Zinc or Galvanised primer.
    Red oxide paint or Hammerite paint.
    Stone chip paint or underseal.
    Wax oil gun to spray inside of repair panel.
    A large swear box
    A continuous flow of cups of Tea / Coffee
    Or you get a bodyshop garage to do the repair work for you, but it'll need all the rusted areas removing / cutting out and welding in new pieces / panels, I say that as some garages only weld pieces of metal over the rust just to get it through the MOT.
    Hope this helps
    Si
    Had MK2 Scirocco Scarla 1998 to 2002
    Now have Corrado 2.0 16v since 2002 still got it
  3. #3
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,198
    This is an old thread from a year or two ago.
    Link below:
    http://the-corrado.net/showthread.ph...body-corrosion
    Si
  4. #4
    CF Nutter
    Join Date
    19th May 2004
    Location
    St.Albans
    Posts
    1,451
    Thanks for the very detailed reply Si. I have got hold of the Golf Mk2 repair section and asked my welder, ( very experienced and interested in making a good job) to fettle it to fit. I will keep you up to date with developments. Maybe others can benefit if this works out well.
    Further comments are welcome in the meantime.
    Best wishes. RB
  5. #5
    Join Date
    9th February 2013
    Location
    Bournemouth
    Posts
    1,198
    Sounds like a good plan,
    hope you get it sorted.
    Si
  6. #6
    Enthusiast
    Join Date
    16th April 2006
    Location
    Bucks
    Posts
    887
    Another amazing post from Si!
    Hats off mate,
Similar Threads
  1. Free: large Corrado O/S repair section - SOLD
    By Stonejag in forum Parts for Sale
    Last Post: 13th February 2015, 3:48 PM
  2. panel repair section
    By VW_OwneR_85 in forum Wanted
    Last Post: 28th January 2015, 9:07 AM
  3. Door handle repair kits now in stock at VW Heritage
    By annavr6 in forum Suppliers Forum
    Last Post: 6th August 2014, 1:08 PM
  4. Replies: 0
    Last Post: 15th January 2012, 12:32 PM
  5. Stainless mid/front section onto a Remus backbox.
    By ross.taylor in forum Engine Bay
    Last Post: 4th December 2003, 12:23 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
