Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Sound deadening carpet underlay
  1. #1
    CF Nutter
    Join Date
    19th May 2004
    Location
    St.Albans
    Posts
    1,455
    The carpets are out due to major floor welding.....before I replace them, is there a good sound insulation underlay that anyone can recommend please.
    And what is the best way to clean the carpets? Washing machine? Hire a carpet wet cleaner/ vacuum?
    Best wishes
    RB
  2. #2
    Newton Commercial do an underlay set, dynamat could be fitted prior to it. As for washing I'd use a wet vac
  3. #3
    Enthusiast
    Join Date
    16th April 2006
    Location
    Bucks
    Posts
    925
    I used a jet washer... my car had stood for 4+ years and had a lot of water ingress... the carpets stank but were not worn. I covered it in soap (Persil from memory) allowed it to soak and jet washed it off, carpet is now mint!
    We used to do this years ago when I worked in a panel shop - car carpet is pretty strong and will dry very quickly... this was out of the car obviously
  4. #4
    ⋆⋆ CF Donator ⋆⋆ robrado974's Avatar
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,330
    Is that the same insulation as Heritage sell ?, I also got the carpet from Newton . I put the sticky grey stuff down first , I got the double insulation and found it was too thick . I struggled to get the seats on the runners. I had to remove one layer of the insulation and I still can’t fit the seat runners plastics on .
    92 VR6 . DBP. She will never be a show car ..... But will be up there with the best of em .
    The bmw seems invincible in isolation . But along side the corrado - a modern classic , we think- it has its work cut out . Autocar 1992.
  5. #5
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,330
    Seriously now considering removing the new carpet and finding a decent old one .
  6. #6
    Enthusiast
    Join Date
    16th April 2006
    Location
    Bucks
    Posts
    925
    I used this stuff, like you I tried the acoustic foam and it's to thick...
    Attached Images Attached Images
  7. #7
    CF-oholic! fla's Avatar
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,523
    Rob, what thickness did you use? 6mm plus a mass barrier should be fine. Perhaps you could trim it slightly by the runners?
    I replaced the soundproofing in mine hs summer with some closed cell foam and a mass loaded vinyl. Noise is now more through the doors but its quieter than before
    Hasan
    VR6 Auto to manual conversion, beige leather, aircon, TT comps, blue dash lights & switches, Koni TA/Nothelle springs, OBD2, 264 cams, Schrick
    my car
  8. #8
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,523
    Roger i just used some persil and a hard brush on mine. They dried quite quickly although it was during the summer. Makes them smell nice too!
    Hasan
    my car
  9. #9
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,330
    Quote Originally Posted by Geeba View Post
    Mine is very similar to this , I bought the deluxe set , which is basically double . I did use the closed cell product as well Hasan . I’m not sure what to do with it at the moment.
    As for cleaning the carpet, I put mine in the washing machine .
  10. #10
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,330
    Just to be clear . I used closed cell first, then the deluxe underlay. I tried to put the new carpet down and it proved difficult. I then removed one layer of the underlay but struggled to get my seats in , let alone the plastic runners . I’m repainting the seats over the winter so I will take another look. The newton carpet is thicker than the Oem one too , it’s not very forgiving when fitting either.
Similar Threads
  1. Sound proof or double underlay ?
    By robrado974 in forum Interior
    Last Post: 13th November 2015, 8:04 PM
  2. Carpet under felt / underlay options
    By Thursdave in forum Interior
    Last Post: 22nd November 2014, 5:12 PM
  3. Black Carpet and underlay
    By knight5651 in forum Wanted
    Last Post: 28th March 2012, 11:27 PM
  4. Replies: 3
    Last Post: 5th January 2012, 3:16 PM
  5. help ,carpet underlay soaking
    By volksworld13 in forum Interior
    Last Post: 1st December 2009, 6:33 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
