Results 1 to 4 of 4
Thread: Fan stays on long after engine has been switched off...
  1. #1
    Newbie FrankyEight's Avatar
    Join Date
    4th April 2016
    Location
    Surrey
    Posts
    77
    Hi guys,
    As title, my fan stays on long after I've switched the engine off. Any ideas? In a separate issue, my car is also high idling (1000rpm)once it gets to normal temperature. Only when I switch the engine off and back on again does it 'reset' bakc to normal (750rpm) idle. Could these issues be linked? Temperature switch or something?
    Many thanks, it's a 95 9A.
    1994 SHERRY PEARL 16V
  2. #2
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,953
    I'm not sure on the 9A but the VR6 fans run on for some time after switch off. How long does it stay on for roughly? The fan is regulated by water temp though, and idle is by the oil temp via the ecu so won't be linked. Idle issues can be a plethora different things so worth doing a search to see if others have experienced similar symptoms, and go from there.
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  3. #3
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,781
    Replace the fan switch temperature sender in the radiator.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  4. #4
    Join Date
    4th April 2016
    Location
    Surrey
    Posts
    77
    Thanks, guys. I'm going to monitor the fan situation as it seems ok the last couple of days. Regarding the idle issue, it's not lumpy, it's just as if, once the temperature has reached normal level, my revs rise to 1000rpm as if I'm starting from a cold start again. I'm thinking about changing the thermostat... Can anyone tell me the best place to find one for my 9a? Cheers!
Similar Threads
  1. Switched power in engine bay
    By sam2.0 in forum Engine Bay
    Last Post: 15th April 2012, 6:02 PM
  2. Switched Live in engine bay - Where to find one?
    By mariojoshi in forum Engine Bay
    Last Post: 27th May 2010, 5:51 PM
  3. VR6 rad fan fails to work with engine switched on
    By markrtw in forum Engine Bay
    Last Post: 1st April 2008, 9:01 AM
  4. Warning light stays on for to long!
    By Matty Newquay in forum Engine Bay
    Last Post: 28th March 2007, 5:26 PM
  5. engine cooling when switched off (G60)
    By Sandy in forum Engine Bay
    Last Post: 23rd July 2006, 10:57 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
