Results 1 to 7 of 7
Thread: '94 Corrado VR6 Stealth Turbo
  1. #1
    ⋆⋆ CF Donator ⋆⋆ poll250's Avatar
    Join Date
    25th January 2007
    Location
    Oxford
    Posts
    1,001
    I've had this car for nearly 12 years and have taken it from Standard, to what I'd say was one of the best Corrado's in the country. Full spec below but basically it's a VRT with LSD, Traction Control, Big brakes etc. No expense was spared in this build and I have a folder full of a scary amount of receipts to prove it!
    Although I still love it, it's sat on my parents driveway for the last few years, getting driven up and down the road on a monthly basis, but it really is time I moved on and let it go to a new home.
    Specs are as follows;
    M Reg Aqua Blue Pearl Corrado VR6
    Currently SORN
    160k
    380Bhp, 375 lb/ft
    Exterior
    Paint is pretty good for a 24 yr old car, but does need some polishing work + the usual small dents and scrapes to be expected.
    Clear Oval repeater
    50mm Spliter
    Red film tinted Lights
    Lupo Wipers
    Engine bay
    Stealth Racing Stage 1+ Turbo conversion: T60/1 Turbo with Garrett internals,FMIC, chrome pipework, manual adjustable Forge recirc valve, later CP ecu and 4" MAF housing.
    Rebuilt VR engine fitted approx 10k ago.
    8.5:1 Headspacer, Autotech 262 cams, ARP Head and Rod bolts, Bosch Green top Injectors
    All new engine sensors, thermo housing etc
    Dubpower Ht leads
    Complete Custom 2.5 inch Stainless exhaust system built at Stealth, no cat is fitted, doesn't sound too boomy at all.New rubber hangers fitted
    Vibratechnics Rear Engine and Gearbox mount, BlackForestIndustries Front Mount. Holds everything steady with no excess vibration from cold.
    Wallbro in tank fuel pump
    13 row Mocal Oil cooler, new standard heat exchanger and pipes with longer bolt
    New Genuine Radiator + elbow (one of the last left of each)
    Uprated Headlight Loom + Osram Nightbreaker Bulbs
    Drivetrain
    Racelogic Traction Control (with Launch Control) Really helps get the power down and eliminates wheelspin very subtly.
    Fixed Steering column with the last fixed cowling available!
    New wheel bearings front and rear,r32 wishbone bushes, Ball joints, Track Rod ends, Subframe bushes,Powerflex rear axle bushes
    Gearbox rebuilt by Riccardo in Leamington (they make the gearbox for Mclaren Mp12-4cs) and a Wavetrac LSD was fitted, new seals and bearings where needed.
    Lightened and balanced Flywheel
    New Helix clutch with heavy duty release arm
    Audi S3 shift tower, TTweight and cables, mounted into OE Polo housing. Fits perfectly and gearshift is as good as a modern car.
    Suspension/Brakes
    17x7.5" Genuine BBS RC 323 alloys with Kumho KU tyres. Arguably one of the best wheels on a Corrado
    10mm H&R hubcentric spacers front and rear
    Weitec Hicon GT height adjustable coil overs.
    Front: Porsche Boxster Brembo front callipers with standard VAG 312mm discs, Ferodo DS2500 pads. Pedal feel is really good and stopping power is great!
    Rear: MKIV Golf rear Callipers with standard discs and Pagid pads
    Goodridge raided front and rear lines
    Weitec rear ARB
    Interior
    Recondtioned Standard Cream leather seats +doorcards
    Black A,B & C pillars
    Headunit with rear aux in
    Panasonic speakers and tweeters
    320mm Momo Race steering wheel
    DDI backlit dials and Reverse LCD
    Red LEDs in switches
    New Headlight switch
    New Window rollers
    Chrome door pulls and pins
    Silent coat sound deadening in doors pods, rears also filled with bubble wrap. Doors close with a nice thud.
    EL Sheet Backlit heater controls red/blue colouring
    Audi S-line Gearknob
    Bad points:
    Wheels could do with a refurb
    Needs 4x new tyres
    Heater control direction knob is broken, currently set on windscreen/face (may also fix myself)
    Paint bubbles under inner arches
    Small coolant hose leak
    The car starts and drives fine, but will need to be towed/trailered away.
    Price – Open to offers.
    Quick video of it running
    Thanks,
    Andrew
    Poll
    C63 AMG Coupé +
    Corrado VR6 Turbo
    GONE: Porsche Cayman S / E46 M3
    Aqua-Blue Pearl | Stealth Turbo | Custom Exhaust | 17" BBS RCs| Wavetrac LSD |Racelogic TC | 262s | ARPs | Cream Leather | Weitec Hicon GTs + Rear Arb | 312 Brembos + Mk4 rears | Aero Wipers | DDI | Momo | Mocal | S3 Shifter |Fixed Column...
  2. #2
    ⋆⋆ CF Donator ⋆⋆ lilfuzzer's Avatar
    Join Date
    25th August 2004
    Location
    County Durham
    Posts
    5,938
    Wow mate long time mate
    nice car this glws
    Chris
    93 Bordeaux Pearl VR6 'Verity'
    94 Blackberry VR6 - not anymore
    Project number 28
    94 green 8v
    previous rados
    91 Bordeaux pearl 1.8 16v
    94 Sherry Pearl VR6
    93 Bordeaux pearl VR6
    93 Aqua Blue VR6
    94 Moonlight Blue VR6
    95 Silver 16v 2.0
    95 White 8v
    93 Flash Red
    94 Classic Green VR6
    unknown blackberry VR6
    94 green 8v
    90 green 16v
    94 Black 2.0 16v
    91 Blue 16v
    91 Black G60
    94 Grey 16v
    92 green 16v
    94 Ice Violet VR6
    too many
  3. #3
    Perfect spec!!!! Really wish I had the money! best of luck with the sale!
  4. #4
    CF-oholic! coullstar's Avatar
    Join Date
    20th November 2002
    Location
    Aberdeen
    Posts
    5,213
    Probably the only thing that would tempt me back into one.
  5. #5
    Join Date
    25th January 2007
    Location
    Oxford
    Posts
    1,001
    Quote Originally Posted by coullstar View Post
    Open to offers mate!
    Poll
    C63 AMG Coupé +
    Corrado VR6 Turbo
  6. #6
    Join Date
    20th November 2002
    Location
    Aberdeen
    Posts
    5,213
    RS4, 996 and young family means zero cash!
    RS4 + cash my way? Lol
  7. #7
    Join Date
    25th January 2007
    Location
    Oxford
    Posts
    1,001
    Tempting but I also have a C63 I don't drive nearly enough!
    Poll
    C63 AMG Coupé +
    Corrado VR6 Turbo
Similar Threads
  1. Replies: 86
    Last Post: 27th January 2017, 4:34 PM
  2. Storm Stealth Turbo
    By n3p in forum Cars for Sale [Corrado]
    Last Post: 23rd June 2015, 12:42 PM
  3. Stealth turbo on a rebore..?
    By Hisnibs in forum Engine Bay
    Last Post: 1st February 2015, 1:58 PM
  4. possible favour- anyone got a stealth turbo vr and going to national day?
    By VAG-hag in forum Event Announcements & Discussion
    Last Post: 25th May 2013, 7:40 AM
  5. STEALTH VR6 TURBO
    By corradoSTORM man in forum General Car Chat
    Last Post: 19th April 2004, 8:26 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
