Results 1 to 6 of 6
Thread: phenolic coilpack spacer
  1. #1
    CF-oholic! sexybourbon's Avatar
    Join Date
    14th February 2010
    Location
    hull
    Posts
    3,195
    updated add - second batch now available for some people that missed out on the first or didnt see the post , iv kept the origional add below
    Hi all i hope this is ok to post on here
    after owning my vr for 7 years and going through three coil packs i thought id adapt the same idea as my phenolic inlet manifold gasket to the coil pack to help protect it and prolong the life of it
    iv had the idea for a while and decided to get this sorted as there are non available to buy in the uk
    its a 6mm pacer cut plate with four new allen head bolts to fit directly to the car , it sits on the side of the engine and in between the coil pack to stop the metal to metal contacting and transfaring heat which in return after time is what makes them crack causing misfires and bad running
    iv already sold a few but have about nine left but could get some more done if there is demand for them
    id like 25 pounds for one posted
    coil packs are pretty expensive these days for a decent one and if your like me then your probably sick of them cracking
    you can pm me on messenger if you would like one or have any questions
    im having problems with loading pictures to the forum and i cant seem to find the corrado forum on tapa talk so if you would like pics i can send them via whats app or messenger no problem
    my number is 07980690184
    message anytime im up most of the day and night
  2. #2
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,731
    Sounds like a good idea - I'm on a distributor, but would definitely go for one of these if I had a coil pack car. As an aside, is there any real reason for why it has to be attached to the head at all? Surely you could just have it mounted safely away from the block and the heat. Does it earth via the block?
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  3. #3
    Join Date
    14th February 2010
    Location
    hull
    Posts
    3,195
    its the ht leads that would need to be made longer and in my opinion would make it look a bit scruffy
    another thing that i thought of was making something to relocate but people like parts to be in the standard place that vw put them
    the plate only takes 10 mins to fit and drops the temps of the coilpack so works really well
    and as for the eearh there is no problems at all
    it still works perfectly and iv been runni g on on my supercharged car for the last few months
  4. #4
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,731
    Ah ok - sounds good so.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  5. #5
    Join Date
    14th February 2010
    Location
    hull
    Posts
    3,195
    i think so mate , i did some testing with a digital temp gun and the coil pack was cooler each time with the spacer installed
    considering they break so often ,judging by how many bad running threads you see due to coilpack failure (they always crack ) and wanted threads for second hand coilpacks id say this wasnt a bad investement considering the price of a good quality new one
  6. #6
    Join Date
    14th February 2010
    Location
    hull
    Posts
    3,195
    There was a chap on here who sent a private message
    I have replied but now can't find the message so if you haven't received it can you pm me again with a number or email to contact you on
    Cheers
Similar Threads
  1. BBS alloys what spacer do I need
    By John Blount in forum Exterior
    Last Post: 10th February 2016, 11:11 AM
  2. 20mm spacer
    By SR_Neale in forum Drivetrain
    Last Post: 15th January 2016, 5:27 PM
  3. spacer gasket help!
    By j4y vr in forum Engine Bay
    Last Post: 25th February 2013, 11:26 PM
  4. vr6 Phenolic spacer - exhaust side?
    By VR6Will in forum Engine Bay
    Last Post: 24th April 2012, 10:43 PM
  5. To spacer or not to spacer?
    By polo_corrado_rims in forum Exterior
    Last Post: 12th August 2011, 4:52 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
