Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
Thread: Help! I'm considering a French car!!!!
  1. #11
    ⋆⋆ CF Donator ⋆⋆ swiftkid's Avatar
    Join Date
    24th May 2007
    Location
    Near Hull
    Posts
    2,817
    Do not under any circumstances buy french, the build quality is so poor I would be worried about things falling off in a slight breeze. My wife had a clio dci sport thing she used to commute in and it was forever eating slave cylinders which helpfully is internal so gearbox out job and also blew a turbo by snapping the shaft completely in 2! as well as most of the interior coating peeling off and all the door seals tearing and just waving in the wind. Also, having driven it to Devon a few times, was the most uncomfortable thing I have ever had the mispleasure of being in.
    We now have an A3 TDI which is good, quite comfy and handles well but on motorways isn't amazing on fuel, still good for a diesel but not how I expected.
    The little ibiza's, lupo tdi/sdi apparently do bonkers mpg (70-80mpg), but couldn't tear the skin off custard.
    If you want something a little older I cannot recommend E46 320d's enough, had mine about 5 years now, just hit 205k in it and it just never skips a beat *touch wood*. It's comfy, goes well and because it's an M sport looks good as well. Doesn't have DAB but can always add it. And because they were designed for rep's just eat the motorway miles
    Red 16v gone
    Red VR32.. WIP
  2. #12
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,976
    Thanks all so far. I think it's now a toss up between a Fabia, Ibiza, Mini One Cooper D, Fiesta, and the 208. They all have good and bad points - Fabia is a bit bland but a decent all rounder, Ibiza is basic in the way of mod cons but cheap, Mini, well, it's a bit of a hairdressers car and the most expensive out of the lot but is well put together. I find the interior of the Fiesta pretty hideous, but it's cheap to run and repair, and the 208 has poor build quality, but is the most stylish inside and out of the lot, and you get tons of extras on even the most basic models......
    I've driven them all bar the Ibiza over the last few years but hard to make a comparison over such a long period. Think I'll have to test them all again.
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  3. #13
    There's absolutely nothing wrong with French motors.
    They're no more unreliable than anything else I've ran. No extra rattles or squeaks.
    They don't rust any more than anything else and bits don't drop off.
    In fact I can say that in all honesty the least reliable cars I've ran have been German.
    Don't believe the hype.
    1993 Corrado VR6 in Flash Red
    1970 Beetle in Clementine
    1987 Citroen 2cv Charleston (honest)
  4. #14
    CF-oholic! delfinis38's Avatar
    Join Date
    24th February 2006
    Location
    Muckle Flugga & Fastnet Rock
    Posts
    3,399
    If your considering a fiesta, why not a sporty polo.... I do rate them....
    Corrado VR6 - Aqua Blue LC5U - 96 'N' Plate
    Black Leather - Heated Seats - Air Con
    Totally Standard and intend to keep it that way !
    Hibernation for Winter ! SORN
  5. #15
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,976
    Because it's all about the absolute maximum in economy, so unfortunately sporty doesn't link in all that well. I have looked at Polos as well, but bang for buck I think the Ibiza but mostly the Fabia comes out on top of the VAG range
    CCGB #3982
  6. #16
    Join Date
    24th February 2006
    Location
    Posts
    3,399
    anything with a sunroof I describe as sporty...
  7. #17
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,839
    Don't let ultimate economy rule over ultimate running costs. EG modern VAG diesels have fragile EGR valves, DPFs can be an issue on low mileage as well as high mileage cars, then there's DMFs and clutches, turbos etc - any will give you a bill of around £800 with very poor access around the engine bay hampering DIYing.
    All the above makes you current car look promising even with the £1000 of repairs needed for another 12 months motoring?
    For me I'd be looking for a 1.9 TDi pre DPF diesel as everything is cheap and simple to repair
  8. #18
    ⋆⋆ CF Donator ⋆⋆ Wullie's Avatar
    Join Date
    28th January 2009
    Location
    Paisley, Scotland
    Posts
    1,650
    I have an older Renault and while pretty reliable the electrics are fragile and home repairs are frelling awkward. Access is difficult and most tasks take ages due to the location and access problems, not including mad construction techniques. Noticed a small leak from the rocker cover and discovered that the camshaft bearings are built into the cover meaning you have to remove the timing belt and from there on it just got worse. Garage cost would have been in the region of £550/£600. Other jobs are just as awkward, took me 20 minutes to find the starter motor. For it's age though it's pretty good on petrol.
    Alpine White 1990 1.8 16v gone to a new home.
    Current mode of transport 2001 Megane Cabrio, apologies.
    The older I get the more I recall how little I knew when I knew it all.
  9. #19
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,976
    Well I stopped off to have a look at a few on the way home today. Just sat it them and got a feel for how they are and comfort levels etc.
    Mini is way too small. I'm 5.10" and even with that, the seat was right the way back and pretty much up against the rear seats. With 2 kids, even on the occasion that they'd be in, its a no. The Citroen is as mentioned, very poorly put together and felt very cheap and tacky. The Fabia was just dull. As much as its solid, the plain single colour dark grey plastic all over is just so bland. The seats aren't at all comfortable either. The Ibiza wasn't bad, though it was an FR so seats were a little more supportive than would be standard, but again I wasn't overly enamoured with it. And the 208 was better than I thought it would be. It wasn't the car for me (1.2 petrol) and although the plastic is a little thinner than that in the VAG range, the different shades of black and different textures, with plenty of options available and decent levels of comfort in the cab drew me. The only down side was I couldn't find the steering wheel reach/rake adjuster which I think I'd need to make the driving position correct for me. I'll be looking at one again, and also the Clio as they are similar in most respects. Unless you're looking at top spec cars in the VAG range, they just seem very basic in comparison.
    I've taken in what everyone has said, but it'll be all motorway miles I'm doing and it only really needs to last for 3 years when I'll be on the cusp of finishing in my current career path.
    CCGB #3982
  10. #20
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,976
    Well, I've done it. I've put a deposit down on a 2015 Pug 308 1.6 BlueHDI. Should be picking it up within the next week but have to sort out storage for sale of the Passat (No space in the garage!) and wait for the wife to find a new car too so we can sort insurances out.
    The quoted figures on it are phenomenal, so the small amount of finance I've got will be more than offset by the fuel saving alone (even if I only manage the urban figures on a run it still works out 60% better than the Passat). Free tax as well, and its really tidy. Drives great, 120bhp so plenty powerful for what I need, loads of toys and everything seems to work! The only thing I'm a little nervous about is the touch screen console, as it controls absolutely everything including the heaters!
    CCGB #3982
Similar Threads
  1. French connection
    By GZAV in forum Newbies Hangout
    Last Post: 17th November 2017, 10:47 AM
  2. French Headlights
    By diarmaid16 in forum Exterior
    Last Post: 15th March 2015, 5:14 PM
  3. New French Corrado owner
    By djlowd in forum Newbies Hangout
    Last Post: 19th February 2013, 10:27 AM
  4. French Trip
    By surfer.vr6 in forum General Car Chat
    Last Post: 22nd January 2006, 8:49 PM
  5. French Car Show on Sunday...
    By Jim in forum General Car Chat
    Last Post: 30th May 2003, 2:16 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
