Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Abs again
  1. #1
    Enthusiast
    Join Date
    23rd April 2017
    Location
    Liverpool
    Posts
    382
    Abs again
    A bit of history,
    Last year none start,next day starts,runs ok,ABS light on when cranking only go’s out when engine starts,
    Pull the Corrado out of the garage tonight (fist time in 3 months),No ABS light on at all ignition on or cranking,engine starts the ABS light comes on very dim,Remove the lower wiring block on the ABS unit (engine running) the ABS light go’s out.Last time I checked the ABS was working ok .
    Any ideas ???
    It’s a 2.0 16 v 1993
  2. #2
    Quote Originally Posted by 1200 bandit View Post
    A bit of history,
    Any ideas ???
    I'm not sure I understand what the problem is, but you know the ABS light comes on at startup and stays on until hydraulic pressure builds up high enough to switch it off. I wouldn't recommend unplugging any connectors that attach to the ABS computer while the car is running just as a precaution.
  3. #3
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,970
    ABS light should come on with ignition and then go off after a self test, the same when starting. It could be the bulb in the switch itself going weak, or a problem on the circuit board in the switch.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  4. #4
    Enthusiast
    Join Date
    23rd April 2017
    Location
    Liverpool
    Posts
    382
    Quote Originally Posted by a_riot View Post
    Just check the bulb in the abs light working ok.
    Check the wiring to the abs light get 8.9 votes on pin 4-8 ( bulb wiring)
    When turn on ignition no abs light comes on,start engine the abs comes on very dim
    Gets the knock though the brake pedal ignition on
  5. #5
    From what I recall the abs computer connecting block in the passenger footwell is notorious for getting wet and rusty and providing a poor contact. Check here to see if you can improve things by cleaning the contacts there. This usually means the wing drains are blocked or you have leaks from the scuttle area.
  6. #6
    Enthusiast
    Join Date
    23rd April 2017
    Location
    Liverpool
    Posts
    382
    The footwells are bone dry no water leaks inside the Corrado,l did remove the glove box and tidy up the wiring on the n/s in the summer but has not moved fo 3 months
    I did see the is 2 30 amp fuses behind the glove box any idea what they are for cheers Wayne
  7. #7
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,989
    Those fuses and relays behind the glove box are for the ABS system.
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  8. #8
    Enthusiast
    Join Date
    23rd April 2017
    Location
    Liverpool
    Posts
    382
    Thank you all for the information,if anyone has more information please share,
    I have looked on here and can not find a seminar fault for abs
  9. #9
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,970
    Good call on the ECU I think - even if the foot well appears dry, you can get water/moisture leaking into that recess that it's mounted in and the unit itself is not sealed, so it's definitely worth cleaning the loom connector and contacts and possibly even testing with a known good ECU if you can get hold of one. Something is wrong if it's not sensing ignition on or sending enough juice to the bulb. Would you not expect to see close to 12V at the bulb? It's worth a shot anyway.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  10. #10
    Enthusiast
    Join Date
    23rd April 2017
    Location
    Liverpool
    Posts
    382
    Getting 8.9 volt to the bulb so it’s looking like a earth fault???
    Will try and get to it at the weekend,but charges it will be after Christmas
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
