Results 1 to 7 of 7
Thread: Outer window seal scrapers fit poor
  1. #1
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,144
    I changed my outer window seal scrapers a while ago with some from vw heritage. They have never seemed to fit properly. They don't push down enough onto the door so they don't touch the glass very well.also were I park I get bits off a tree getting into the door because of the gap.i also think it's the cause of my glass rattle as it didn't do it with the old ones.anyone else had same problem
    1990 1.8 16v white
  2. #2
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,892
    There is a lip on the bottom inner edge that should fold into the shape of the door. If its sitting proud, it'll keep the top edge pushed out. Its just not quite sitting correctly, so needs to be either removed and refitted, or manipulated a little bit. Do it with the window down and use a flat plastic tool of some sort to push the lower inner edge into the door whilst pushing the top of it down with your thumb.
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  3. #3
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,144
    Cheers I will give it a go in the daylight. I was pretty sure it was down all the way tho
  4. #4
    ⋆⋆ CF Donator ⋆⋆ robrado974's Avatar
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,170
    My drivers side is the same .
    92 VR6 . DBP. She will never be a show car ..... But will be up there with the best of em .
    The bmw seems invincible in isolation . But along side the corrado - a modern classic , we think- it has its work cut out . Autocar 1992.
  5. #5
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,144
    Quote Originally Posted by robrado974 View Post
    its not just mine then.its hard to explain but its like they are made upside down
    1990 1.8 16v white
  6. #6
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,170
    Can you put a pic up on here or the CCGB page or corrado fb page ?. Mine are new. The passenger side is perfect, but the drivers side has a gap .
  7. #7
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,144
    I will try at weekend
    1990 1.8 16v white
Similar Threads
  1. Nearside passenger outer window seal
    By Fuchs in forum Wanted
    Last Post: 24th July 2016, 2:41 PM
  2. Left outer window seal
    By JimmyC92 in forum Wanted
    Last Post: 5th May 2016, 2:42 PM
  3. Nearside Window outer door scraper seal
    By branty in forum Wanted
    Last Post: 27th January 2016, 8:54 PM
  4. Window Slot seal, Left outer
    By WheelerDave in forum Wanted
    Last Post: 2nd January 2016, 9:19 PM
  5. outer window scraper seal
    By carrots in forum Wanted
    Last Post: 10th July 2013, 12:00 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
