Results 1 to 8 of 8
Thread: ABS light stays illuminated
  1. #1
    Newbie here, Iím going to view a vr6 tomorrow which looks like a lovely example, only issue it has is the abs light is on. From a little googling Iíve found the most likely fault is a sensor. Then others could be ABS pump,ABS ecu, or the brake pedal position sensor. I was just after some info on possible cost for each, and if parts are easily available.
    Thanks
  2. #2
    Yeah, the sensors are easy to get, and the rear sensors are more expensive but in general this is no big deal. The pump unit however is hard to come by and generally many hundreds of pounds. That said they are quite reliable so you can easily chance it on a used one with minimal risk. They can also be refurbished for a couple of hundred quid if you'd like to have a warranty.
    [ WARNING: the above message may contain irony, sarcasm and outright lies. ]
    ** Every time you think about sex, another Corrado gets written off. **
  3. #3
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,732
    The ABS pump unit can be had new from VW for well over €2500! Second hand ones can be around €100, bur there is no real way of knowing if they are ok and many of them suffer from the same damage to the loom connector and control PCB that is mounted on the underside of the unit. ABS ECUs are easy enough to find but rarely go unless there is water damage. Could also be the pedal position sensor in the servo - this can be repaired - do a search on here. Cheap sensors tend to be false economy so buyer beware, and also if the ABS sensor rings are damaged or bent, this can give a false reading.
    If you have a chance, it would be worth scanning the fault codes first, which might give you more of an idea - it could be a really cheap and easy fix if it's a sensor, or potentially a lot more if the pump unit is knackered. There's lots of info on here.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  4. #4
    Thanks for the reply, I do have a cose scanner but from what Iíve read online that you need VAGCOM to access the ABS ecu to diagnose the fault?
  5. #5
    If it was the pump, and I went for the refurb option how much labour time is it to remove and fit roughly? Just so I can factor that in if I make an offer.
    Many thanks
  6. #6
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,717
    Mine took around 20 mins to remove, they don't bleed up well after refitting, so 2 hours to get a decent pedal afterwards
  7. #7
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,951
    As mentioned you'll need to factor in the cost of brake fluid, as it'll need a full system refresh and bleed after replacing the pump. BBA Raman refurbish them so there are ways should it be the culprit. Pedal position sensors are easily repaired also and not too expensive, and I've never had problems with cheap ebay wheel speed sensors. Have a look in the Wiki section at the buyers guide too, lots of good info on what to look for in that. Good luck!
    You can also check the wheels sensors using a multimeter at the plug where it connects to the loom (Front are on the turrets and backs are under the rear seats.
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  8. #8
    Vagcom is not required, a generic code reader will get the code but you'll have to decode them yourself. Obdeleven works too tho, and works on your smartphone. Very handy and not ridiculously expensive.
Similar Threads
  1. Battery Light Stays on
    By 16vMatt in forum ICE 'n' Secure
    Last Post: 5th April 2016, 2:38 PM
  2. ABS light stays on
    By sedwardsvr6 in forum Engine Bay
    Last Post: 14th February 2010, 4:40 PM
  3. Replies: 5
    Last Post: 31st May 2006, 3:31 PM
  4. HELP! ABS LIGHT STAYS ON
    By khurrado in forum Drivetrain
    Last Post: 4th January 2005, 4:29 PM
  5. ABS Light Stays On!
    By Supercharged in forum Interior
    Last Post: 16th June 2003, 9:44 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupť! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
Follow us
advertising & sponsorship
