Results 1 to 9 of 9
Thread: Front camber adjustment amount?
  1. #1
    Enthusiast
    Join Date
    7th May 2003
    Location
    Aberdeen, United Kingdom
    Posts
    383
    I am getting my front camber and alignment set next week as one of my cambers was out by -2.25 last check.
    The guy that is doing it says not to bother getting camber bolts as he will see if he can get it with the standard bolts in.
    Is this possible to get with standards or should I just order camber bolts? I don't want to not get enough adjustment then have to order then go back again, but I also don't want to spend if not needed!
    The come in pairs, so do I need 4 in total or just 1 for each side?
  2. #2
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,904
    They are adjustable, the strut just moves in and out where its bolted onto the hub knuckle top and bottom, which allows adjustment.
    Should be -0.5 from factory from memory.
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  3. #3
    I think a lot of these cars are just a bit bent after all this time...
    [ WARNING: the above message may contain irony, sarcasm and outright lies. ]
    ** Every time you think about sex, another Corrado gets written off. **
  4. #4
    Enthusiast
    Join Date
    7th May 2003
    Location
    Posts
    383
    I understand they are adjustable but will it be enough on standard bolts to get back from -2.25?
    I have Koni Coilovers, which are dropped about 1 inch.
  5. #5
    Enthusiast
    Join Date
    7th May 2003
    Location
    Posts
    383
    Any more thoughts on this guy's?
  6. #6
    ⋆⋆ CF Member ⋆⋆ Jim Bowen's Avatar
    Join Date
    16th May 2005
    Location
    Essex
    Posts
    8,941
    I've always managed to get mine to -1 with standard bolts etc
    Just like a golf................But better!!!
  7. #7
    Enthusiast
    Join Date
    7th May 2003
    Location
    Posts
    383
    Quote Originally Posted by Jim Bowen View Post
    Thats great, what figures were they at before adjustment?
  8. #8
    ⋆⋆ CF Donator ⋆⋆ tonedef's Avatar
    Join Date
    4th October 2006
    Location
    Cuckney
    Posts
    964
    Quote Originally Posted by skid View Post
    It depends where it is in the slot before you start. -2.25 could be the least possible camber you can get if something else is bent, alternatively it could currently be all the way in with 2 or more degrees of adjustment available. It’s pretty agricultural to set up but generally does the job!
    95 Classic Green VR6: Climatronic & OBD2, Grey Leather Recaro Interior
    CCGB No. 58
  9. #9
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Colchester, Essex
    Posts
    701
    i'm set at -1 degree on the standard bolts and kw coillies
Similar Threads
  1. Front suspension camber adjustment
    By Roger Blassberg in forum Drivetrain
    Last Post: 31st May 2011, 7:45 PM
  2. DIY Camber adjustment
    By Kick Up The Rs in forum Drivetrain
    Last Post: 15th August 2006, 10:07 AM
  3. Camber Adjustment in MK...Help!!!!???
    By blue95 in forum Drivetrain
    Last Post: 1st March 2006, 11:51 AM
  4. camber adjustment
    By Rick in forum Drivetrain
    Last Post: 4th December 2005, 4:42 PM
  5. Run out of camber adjustment
    By Neil VR6 in forum Drivetrain
    Last Post: 1st July 2005, 7:31 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
