Results 1 to 6 of 6
Thread: drivers seat base foam
  1. #1
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,145
    just got out of car and I could feel steel on the drivers seat bottom side bit.is it a hard job to do ive done a quick search and it looks like you cant buy new foam .another job to the list
    1990 1.8 16v white
  2. #2
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,897
    It’s an easy job but as you’ve mentioned, you won’t find a replacement unless out of a passenger side seat that someone is breaking. A good upholsterer may be able to make you a new one based on your current one though
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  3. #3
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,145
    can you tell me what I need to do to fit um.cheers
    1990 1.8 16v white
  4. #4
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,897
    Remove the seat from the runner, separate the back from the top by removing the bracket trim and securing pins, then you'll see the teeth that are holding the covers in place. Just peel them back gently with a flat trim tool or screwdriver and take it off. The bolsters then just lift off. Reverse to fit the new one, Job done.
    CCGB #3982
  5. #5
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,145
    cheers doesn't sound to bad to do
    1990 1.8 16v white
  6. #6
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,897
    The only problem you'll have with removing the top, is the headrest leg trim things as they are quite difficult to remove from the seat backs.
    Be careful on the tilt handles when removing them too.
    CCGB #3982
Similar Threads
  1. recaro seat base
    By nicksta in forum General Car Chat
    Last Post: 22nd April 2015, 9:28 PM
  2. Drivers seat base or cheap drivers seat.
    By peterdinosaur in forum Wanted
    Last Post: 14th July 2014, 2:19 PM
  3. Replies: 6
    Last Post: 26th February 2014, 4:55 PM
  4. Replies: 8
    Last Post: 30th June 2012, 9:32 AM
  5. Seat runner/base
    By Big Adam in forum Wanted
    Last Post: 16th November 2011, 4:40 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
