Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Engine swap 1.8t advice
  1. #1
    Hi there I'm new to the forum and to corrado ownership having just acquired a 1994 2.0 16v. The engine is high mileage and lacking in the power department,
    So I'm thinking of swapping to a 1.8t agu engine but I'd like some advice on doing the swap with regards to parts required.
    I'm not after mega power just abit more than the standard 9a engine.
    I'd also like the setup to be a bit different so I'd like to do away with the turbo and run a supercharger instead, will the standard agu ecu be able to handle a remap that would suit the supercharger.
    Is there anything I should consider before starting this project.
    Little bit of background on me I'm a electrical, mechanical engineer by trade so the project shouldn't be beyond me.
    Any help/advice would be most appreciated.
  2. #2
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,953
    Hi Giles,
    Can't help with the charger, buts its a common engine swap. Have a look here, loads of info available.
    http://the-corrado.net/showthread.ph...ion-20V-Thread
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  3. #3
    Enthusiast
    Join Date
    16th April 2006
    Location
    Bucks
    Posts
    919
    If you want to be different keep the 9A engine! LOL! - they seem to be the first to get skipped for 18T engines...
    If you're not after huge power which a tuned 18T will give you of course if you have deep pockets, as most are now pretty old and will require a once over in the bearings/rings department... possibly guides/seals.. more than likely a new/refreshed turbo.
    You could do all that on your 9A or fit an ABF maybe... I'm far from a purist but like to keep things roughly how they left the factory
  4. #4
    Thanks for the advice I ll have a read through that thread.
    I also agree with the comments about keeping it standard with the 9a engine which was my original intention just feel the engine isnt worth wasting the money as its held back by the mechanical fuel injection.
  5. #5
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,168
    I was going to put a 1.8t in mine I even bought most of the stuff needed but thought it was a shame to take a perfect engine out.it can work out expensive with cambelt kit clutch and loads of other bits
    1990 1.8 16v white
  6. #6
    Enthusiast
    Join Date
    16th April 2006
    Location
    Bucks
    Posts
    919
    Fit the ABF?
    I'm not sure but I think the ABF head/inlet/injection system will fit the shorter block... could be worth checking for sure - but you could also run it on carbs, they sound like an absolute weapon!
    Not difficult to get 180bhp, cams, head work, manifold etc...
  7. #7
    Thanks for the reply couple of questions now iv got an engine, gearbox, loom and ecu.
    1. Can the standard 9a corrado fuel pump setup work with the agu fuel injection or is not man enough.
    2. Can I use the agu gearbox (not sure on gearbox code will look once iv cleaned it) with my drive shafts?
    Cheers for the help.
  8. #8
    Enthusiast Gti_Jamo's Avatar
    Join Date
    4th October 2012
    Location
    Perthshire SCOTLAND
    Posts
    583
    As said use the 16v and supercharge that. 1.8t have been done to death and are old engines themselves.
    MY 1991 G60 CURRENTLY IN RESTORATION
    http://the-corrado.net/showthread.ph...-Daily-Project
  9. #9
    ⋆⋆ CF Donator ⋆⋆ dragon green's Avatar
    Join Date
    21st May 2008
    Location
    Nr.Tonbridge,Kent
    Posts
    4,016
    The 9a pump if in good condition is good to use,
    Don’t know about other gearboxes,I used an O2a diesel box in mine
  10. #10
    Brilliant thanks for the reply with regards to the fuel pump that will make life easier.
    Iv got the engine and gearbox now in my garage so I can just offer it all up.
Similar Threads
  1. AUE Engine Swap
    By NoisyVR in forum Engine Bay
    Last Post: 23rd July 2017, 6:04 PM
  2. Potential engine swap - any advice appreciated
    By vr6monkey in forum Engine Bay
    Last Post: 27th June 2017, 7:58 PM
  3. advice and thoughts wanted on abf swap into 9a corrado
    By geoffersmaher in forum Engine Bay
    Last Post: 16th June 2014, 10:28 PM
  4. G60 engine build for engine swap.
    By Mr. Bob in forum Engine Bay
    Last Post: 22nd February 2013, 5:46 AM
  5. Alternator belt swap advice
    By jpowell79 in forum Engine Bay
    Last Post: 14th November 2012, 11:15 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
