Results 1 to 7 of 7
Thread: Rear Caliper Binding - Help Needed
  1. #1
    Newbie Hutty's Avatar
    Join Date
    3rd September 2018
    Location
    Nottingham
    Posts
    18
    Had the discs and pads replaced about 1000 miles back. Reversed out of the drive the other day and there was a noticeable grinding noise from the nearside rear wheel. Drove 6 miles in town traffic and noticed that the car wasn't freewheeling properly. Eventually came to a stop but the brake pedal almost went to the floor!
    The nearside rear brake was smoking and I could feel a lot of heat from it. The handbrake still feels like it's moving properly so I'm guessing the calliper is seized. I've no experience with brakes and wondered if it was possible to inspect the callipers to see if they can be cleaned up, or if it's best just to replace with new?
    Pictures would help if anyone has any.
    Cheers.
    Tornado Red G60 - 1993-1995
    Aqua Blue VR6 - 1997-2000
    Aqua Blue VR6 - Current car
  2. #2
    ⋆⋆ CF Donator ⋆⋆ robrado974's Avatar
    Join Date
    22nd September 2009
    Location
    paignton devon
    Posts
    6,174
    As you say the Caliper is seized . If it were me I would replace both Calipers , but go for the MK4 Golf parts. The rear braking is no better, but they are less prone to binding and seizing .
    92 VR6 . DBP. She will never be a show car ..... But will be up there with the best of em .
    The bmw seems invincible in isolation . But along side the corrado - a modern classic , we think- it has its work cut out . Autocar 1992.
  3. #3
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,664
    Check the pads aren't jammed in the carriers, not cleaned up by the fitter before installing new pads.
  4. #4
    Join Date
    3rd September 2018
    Location
    Nottingham
    Posts
    18
    Is it easy enough to check if the pads are jammed in the carrier? Is it just a case of taking out the caliper bolts and having a look?
  5. #5
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,664
    Quote Originally Posted by Hutty View Post
    Yes, the pads should just pull out with your fingers, the fact that the handbrake lever will move suggests the piston is not seized.
    Don’t press the pedal with the Caliper off the pads
    Also check the Caliper slides move in and out freely
  6. #6
    Join Date
    3rd September 2018
    Location
    Nottingham
    Posts
    18
    Thanks for the advice. I lifted the car and the wheel is now spinning fine! No doubt it's just a matter of time before it seizes again, the calipers look pretty corroded so I think I'll replace them with MK4s.
  7. #7
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    24th March 2012
    Location
    Basingstoke
    Posts
    701
    I have issues with mine in freezing overnight conditions where the handbrake doesn't release properly. Maybe water/condensation in one of the cables freezing. Could it have been something like that?
    1994 Corrado VR6
    2007 Mercedes CLS63 AMG
    www.totalfishkeeping.com
Similar Threads
  1. URGENT: Single Mk4 rear caliper needed ASAP.
    By Daveproyoyoyo in forum Wanted
    Last Post: 23rd June 2015, 1:45 PM
  2. Replies: 2
    Last Post: 18th February 2012, 6:13 PM
  3. passenger front caliper binding badly
    By joby in forum Drivetrain
    Last Post: 4th November 2010, 10:03 PM
  4. Replies: 4
    Last Post: 27th April 2010, 10:42 AM
  5. rear calliper binding
    By sciroccotune in forum Drivetrain
    Last Post: 19th December 2005, 9:08 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
