Results 1 to 7 of 7
Thread: OEM style headlining material - where to buy?
  1. #1
    Enthusiast pfnsht's Avatar
    Join Date
    2nd February 2018
    Location
    Herts
    Posts
    379
    Hi,
    Can anyone recommend a place to get some OEM coloured headlining material? I’ve come across a few posts recommending headlining material from here http://www.as-trim.co.uk/index.php?m...Path=5_200_202 but these are from people doing black lining. I did contact AS trim but they were not able to advise from experience.
    Thanks,
    Matt
    1995 White VR6 CCGB Member 4303
  2. #2
    CF-oholic! fla's Avatar
    Join Date
    10th September 2004
    Location
    Middx
    Posts
    6,523
    Why not use some faux suede instead- similar effect to alcantara
    Hasan
    VR6 Auto to manual conversion, beige leather, aircon, TT comps, blue dash lights & switches, Koni TA/Nothelle springs, OBD2, 264 cams, Schrick
    my car
  3. #3
    Join Date
    2nd February 2018
    Location
    Herts
    Posts
    379
    Cheers Hasan. Is alcantara the original material then? I'd be happy to try something similar but need it to match up to my sunroof panel.
  4. #4
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,976
    No the original headlining isn't alcantara. I think what Hasan was saying is that if you re-do it with faux suede, it'll look a little like alcantara which is a more plush material. You'll really struggle getting anything to match your sunroof cassette material. The material is foam backed, which is what is stuck to the headliner. Unfortunately its the material that comes away from the foam which is why its so difficult to put it back on. Your only real option other than replacing the lot, is removing the entire material, using an upholstery glue in an aerosol on the foam, and waiting until its almost dry. You should then be able to put the material on and hope it sticks well. If the glue is still a bit wet, it'll just bleed through the material and you'll end up with crusty patches all over the place. It looks terrible if that happens. I'd just get a decent foam backed beige material and redo the lot. It won't be OEM perfect, but it'll be neat and shouldn't be overly noticeable unless the colour is way off.
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  5. #5
    Join Date
    2nd February 2018
    Location
    Herts
    Posts
    379
    Ahh thanks Sean. My current position is - I've got the headliner out of the car, the old material was ruined so I've got the headliner template cleaned up ready to go for some new material.
    I fitted a new sunroof mech and am now running a passat moonroof with a grey fabric slider panel so not the original. The fabric is very similar to the original corrado stuff.
    Is it possible to retrim the sunroof cassette? I've got two of them to practice on. I thought I had read it can be problematic if material isn't as thin as the original but maybe that applied to the original corrado cassette fabric thinking about it and how it work muchanically?
    If I can do the whole lot that's much easier as don't need to worry about matching up. I'm not that fussed if it's not exactly OEM as was just trying to tie up with the cassette material. Faux suede could work a treat if that's the case.
  6. #6
    CF Nutter
    Join Date
    15th October 2009
    Location
    wrexham
    Posts
    2,181
    I bought some grey faux suede headlining off ebay .it cost about £32 with a can of spray glue.ive not tried fitting it yet tho.how did you find getting the headlining out.
  7. #7
    CF Nutter
    Join Date
    5th December 2005
    Location
    UK
    Posts
    1,057
    https://www.martrim.co.uk/car-trimmi...headlining.php
    Go for high temp spray adhesive as well
    Corrado VR6 Storm
    Corrado VR6 Supercharged+
Similar Threads
  1. FREE Headlining Material + adhesive
    By PaulV in forum Interior
    Last Post: 7th October 2018, 11:10 PM
  2. FREE!! Headlining Material + adhesive
    By PaulV in forum Parts for Sale
    Last Post: 5th September 2018, 8:43 PM
  3. Replies: 6
    Last Post: 16th October 2016, 8:42 PM
  4. Replies: 4
    Last Post: 13th April 2011, 12:58 PM
  5. Replies: 4
    Last Post: 24th September 2007, 8:29 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
