Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Dying Problem
  1. #1
    Newbie
    Join Date
    21st September 2018
    Location
    Reno, Nevada
    Posts
    38
    Dying Problem
    Hey guys,
    So this is a new problem I haven't been able to find on the forum. My Corrado likes to die on occasion. You can't really tell when it is going to die, there aren't really any signs. At first I thought it could be a fuel problem, so I replaced the fuel filter and the fuel pump. But, it is still doing it. I recently noticed that it tends to die when it gets to about 185 degrees. Not sure exactly what it could be. My lights stay on, so it doesn't seem like the car is losing power from the battery at all either.
    Much Appreciated!
  2. #2
    Enthusiast 1xshaunx1's Avatar
    Join Date
    14th December 2010
    Location
    near sheffield
    Posts
    287
    Is that a typo. 185 degrees for water or oil is very bad for the engine.
  3. #3
    Newbie
    Join Date
    21st September 2018
    Location
    Reno, Nevada
    Posts
    38
    its the standard temp gauge in the car. Whenever it gets around half way, the car dies and just shuts off. I assumed it was around 185 just because it has a 160 reading and then a 230 reading so I guessed as to where that temp could be.
  4. #4
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,726
    I assume it's a US car, so the temp gauge will be in Fahrenheit!
    Does the car restart ok when it stops?
    Is there erratic idling as well?
    Does it just cut out when it's running/driving along, or does it happen when you dip the clutch or come to a stop/slow down at junctions?
    I've had some funny behaviour like this when the engine is hot, in particular some faulty wiring to the hall sensor on the distributor that wad caused by a cracked connector heating up and losing contact - it might be worth checking all your loom connectors for damage. Sometimes you also get a vacuum leak that only manifests itself when the engine is up to temp as all the pipes and rubber and plastic will expand, making the leaks worse.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  5. #5
    Newbie
    Join Date
    21st September 2018
    Location
    Reno, Nevada
    Posts
    38
    It is a US car! It use to do it when I would put my foot in the clutch but oddly enough it stopped once I changed the fuel filter and now only does it when it gets up to temp. The idle is ok, not really erratic. The car does restart once this happens that’s why I found it to be very weird
  6. #6
    Join Date
    14th December 2010
    Location
    near sheffield
    Posts
    287
    When you replaced the pump and the filter did you also change the relay under the dash, if not I’d try that next and the ignition switch on the end of the barrel
  7. #7
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,950
    Worth checking the crank sensor too. You should be able to see it at the front of the motor near the bottom left side. It has a hex bolt holding it in and is at a right angle to the motor. Its very common for the plastic to become brittle and crack at the right angle, and cause cutting out when it gets hot. It usually doesn't re-start until temps are down, but worth checking. Other things to check are the throttle damper. Just twist the butterfly valve to open the throttle, and watch it close. It should soft close toward the end to ensure revs don't flat out.
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  8. #8
    Newbie
    Join Date
    21st September 2018
    Location
    Reno, Nevada
    Posts
    38
    Thanks guys! I am going to check all of this possibly today and will post back to say if it is any of that
  9. #9
    It is very common that some VR6s wind up stalling when you drop the clutch on the way up to a junction (i.e. during overrun). I think this is actually caused by a number of underlying issues. One I've heard reported is the idle control valve being sticky. Clean it out, or replace it. Another I've heard is inlet/exhaust manifold leaks causing misfuelling (and associated error codes) as well as causing the stalling. I'm sure there's likely other possible causes too.
    [ WARNING: the above message may contain irony, sarcasm and outright lies. ]
    ** Every time you think about sex, another Corrado gets written off. **
  10. #10
    CF Nutter
    Join Date
    19th May 2004
    Location
    St.Albans
    Posts
    1,451
    There is a damper on the throttle body, looks like a small flying saucer with a piston which stops the throttle butterfly from slamming shut. Check that it is lowering the butterfly gently to its closed position. Replace it if necessary, (very easy so long as you can find a good replacement.
    Check the multi wire connector for the injectors is tight and the contacts are clean. It is a round connector with a fat loom of wires coming out of it on the right side of the cylinder head as you look into the engine bay from the front.
    Next idea is to have your injectors professionally checked for flow rate and spray pattern, and cleaned if necessary.
    Check for any vacuum leaks throughout the induction system, perished pipes and loose clamps etc.
    This is a very common problem with the VR6 engine, but speaking from experience it can eventually be solved so keep us up to date with progress.
    best wishes
    RB
Similar Threads
  1. car dying !!!
    By lil b in forum Engine Bay
    Last Post: 8th February 2010, 7:05 PM
  2. Help - Car is dying lol
    By pp137 in forum Drivetrain
    Last Post: 4th May 2005, 9:39 AM
  3. Dying
    By SteveM16v in forum Archive
    Last Post: 1st December 2004, 1:49 PM
  4. Car is dying on me
    By n8047035 in forum Archive
    Last Post: 5th July 2004, 11:33 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
