Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Eibach and Bilstein B4 shocks
  1. #21
    Newbie
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    50
    Thanks PFNSHT,
    I have just come off the the phone to Larkspeed and he was familar with the issue.
    He told me that its a problem that has been going on for years and that its not age (year of manufacture related) , its just they fit some perfectly and on other Rados are to short. He said Eibach have researched it exstensivley and have still not got to the bottom of it. Sounds to me like a batch of rear springs has gone out that was manufactured to short or VW had randomly different height supensions which is what Larkspeed are suggesting.
    So been advised to get my mechanic to fit the ones I have now and if they dont fit to call them back , but that means my car could be off the road a while a x2 cost for mechanic bit of a bummer. I told him mine was a late model.
  2. #22
    Newbie
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    50
    Tempted to ask for a refund any other recommendations for springs ? 1995 rado vr6
    It actually has H Ans R springs at the moment and sits two fingers above the tire so correct height for 25 mm , it drives awful though with the Koni shocks as i think they are shot or just to damn stiff.
    What are the shelf life of springs , these H and r were fitted in 2003 any good still you reckon lads ?
    Really tempted to go for the B3 Bilstein springs with my new b4 shocks which are basically stock, looks crap with the ride height and everything but you know these cars are getting older and originality is the the thing, also i bet the drive is actually realy good and comfortable.
    What are your thought rado members ?Cheers.
  3. #23
    Regular
    Join Date
    2nd February 2018
    Location
    Herts
    Posts
    221
    I bought my kit from Larkspeed too, they were very good at swapping over even though I bought the kit 6 months before fitting.
    Re: the ride though - I wouldn't have thought there would be much difference between H&R and Eibach springs. Have you got adjustable Koni's? Maybe they've been wound up to their hardest setting. Else Billy B4s should make the ride softer, being a softer shock. One point to note is that B4s aren't designed for shorter springs, that said there is probably enough tolerance in it to cater for mild lowering springs and depending where you read it's often said 20/25mm spring kits were designed to for stock shocks.
    1995 White VR6 CCGB Member 4303
  4. #24
    Newbie
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    50
    Right just come off the phone from larkspeed and mentioned returning and about the B3 shocks.
    He said 98% of the eibach lowering springs do fit correct height and will be so much better the Bilstein B3 springs. So Im going to chance it.
    As regards in using a B4 shock with a eibach lowering spring he said they are actually designed be used with oem shocks in mind , so Im happy about that as always hereing you need the B8 or B6 , I have B4 and Eibachs on a R129 which drives and sits amazing no bumps and really comfortable. Always disagreed with you need the stiffer shocks (with eibach springs) as retailers always push you to go for the more exspensive stiffer shocks. I base this on going no lower then 30mm. He did say H and R springs are much stiffer then eibach so a stiffer absorber would be required in this instance.
  5. #25
    Newbie
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    50
    Your probably right the Koni I bet are on the stiff setting because the car basically bounces over rough roads ha , I reckon if fitted in 2003 and 90 k miles since surely must be past it sell by date.
  6. #26
    Regular
    Join Date
    2nd February 2018
    Location
    Herts
    Posts
    221
    Oh yes most probably well past their best then. I've read the same reports re: eibach pro line / 20-25mm kits and standard shocks. When I was researching the same combo works well across other forums for other makes so it will be fine.
    I had this exact same headache around a year ago so feel your frustration on something that should be straight forward. Fortunately Larkspeed will sort it all out either way.
  7. #27
    Newbie
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    50
    Thanks for all your help mate.
    Just shows though always worth purchasing from the UK for the litlle more cost, for such an occurence of returning product and customer service.
Similar Threads
  1. Bilstein B4 front shocks
    By 0055gee in forum Drivetrain
    Last Post: 22nd February 2016, 3:37 AM
  2. Bilstein B4 front shocks
    By corrado wannabe in forum Drivetrain
    Last Post: 29th January 2015, 12:43 PM
  3. Bilstein Sport Shocks - VR6 Fitment - SOLD
    By daves16v in forum Parts for Sale
    Last Post: 14th December 2012, 10:43 AM
  4. Bilstein front shocks, VR6
    By Andy T in forum Wanted
    Last Post: 19th June 2011, 1:58 PM
  5. Bilstein Shocks
    By StuartFZR400 in forum Exterior
    Last Post: 8th April 2005, 3:22 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
About us
We are the world's largest community for VW's Super Coupé! Be it 8v, 16v, G60 or VR6 (or maybe something else!), everybody's welcome! If this is your first visit, be sure to click register and fill out your details before you can post.
Help us
This site is run on donations.
Please help keep the forum alive!
Follow us
advertising & sponsorship
Are you a company looking for advertising that could benefits our users? For site & forum sponsorship, please see our dedicated microsite here.
