Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Help required diagnosing problem please
  1. #1
    Newbie FrankyEight's Avatar
    Join Date
    4th April 2016
    Location
    Surrey
    Posts
    77
    Hi guys
    I've got a '94 2.0 16v which has the following issue; once the car get's up to temperature, the idle rises from normal (750rpm ish) to 1000rpm and stays there until I 'reset' it by switching off engine and back on again. Even then, after a few minutes of driving it'll rise back up to 1000rpm. I've been told this might be the ISV (idle stabilisation valve?. If so, could someone advise how I remove this and clean it and refit (I'm clearly a novice!). Also, I've been reading that it may be the temperature switch or thermostat? I'm not sure of the difference, again some advice on what the difference is and how they can be replaced would be greatly appreciated.
    Many thanks in advance!
    1994 SHERRY PEARL 16V
  2. #2
    IMHO it's much more likely this is a result of a sensor fault on the engine. Do you have accecss to a diagnostic code reader? VAG-COM or one of the older two-wire diags tools should be able to query the 2.0 16v engine iirc.
    [ WARNING: the above message may contain irony, sarcasm and outright lies. ]
    ** Every time you think about sex, another Corrado gets written off. **
  3. #3
    Join Date
    4th April 2016
    Location
    Surrey
    Posts
    77
    Quote Originally Posted by dr_mat View Post
    Thanks for your reply dr_mat — I don't have access to VAG-COm or the other diags tools... do general garages have this equipment or should I find a VW specialist who does? I'm in Surrey. Cheers!
  4. #4
    Also some prehistory:
    https://www.honestjohn.co.uk/forum/p...ex.htm?t=27965
    Generic reader should work but be aware it's an early four-pin connector not the later SCART socket type. You may as well just get your multimeter out and check the engine temperature sensors have the right resistance.
  5. #5
    Join Date
    4th April 2016
    Location
    Surrey
    Posts
    77
    Thanks — post is really interesting and sounds just like my issue — do you know where the temperature sensor for the engine management system is located exactly so I can check and replace if necessary? Thanks for your patience...
  6. #6
    I believe they're usually on the thermostat housing, but that might just be the VR6 I'm thinking of!
  7. #7
    Join Date
    4th April 2016
    Location
    Surrey
    Posts
    77
    Thanks. Regarding VAG-COM, I might buy a generic reader from eBay or somewhere. They all seem to be SCART. Do I need a 4-pin adapter for this or do I need a specific 4-pin Reader? Cheers again!
  8. #8
    Join Date
    4th April 2016
    Location
    Surrey
    Posts
    77
    Quote Originally Posted by FrankyEight View Post
    Think I've found an adapter!
  9. #9
    Check the compatibility. Even the early VWs with the SCART-type connector didn't actually speak full OBD2 protocols so the reader needs to be aware of this. I've never attempted to get one for a 2.0 16v. You can still get the 4-pin adapters with USB connected dongles that will work with the old 3.11 version of VAG-COM (which is still free from what I recall).
  10. #10
    ⋆⋆ CF Member ⋆⋆
    Join Date
    24th December 2008
    Location
    Crewe Cheshire
    Posts
    3,889
    Could be an air leak? Check all vacuum piping around the engine bay going too / from the manifold etc for splits etc allowing air to enter the engine when the throttle is closed
Similar Threads
  1. Passat ABS problem, Corrado Forum expertise required!!
    By Roger Blassberg in forum Drivetrain
    Last Post: 23rd January 2013, 9:40 AM
  2. G60 diagnosing power loss,help please.
    By stu sleeper 20vt in forum Engine Bay
    Last Post: 23rd November 2008, 3:46 PM
  3. Automatic Seatbelt Problem (+ usual cold start problem)
    By CorradoDriver in forum Interior
    Last Post: 22nd September 2006, 11:32 AM
  4. Replies: 10
    Last Post: 22nd April 2006, 9:38 AM
  5. Diagnosing worn engine mount
    By bigbob in forum Suppliers Forum
    Last Post: 25th July 2004, 8:05 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
