Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Shrick VGI advice
  1. #1
    ⋆⋆ CF Donator ⋆⋆ Keyo's Avatar
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    398
    Shrick VGI advice
    Hi looking for a bit of Shrick knowledge off a fellow member so thanks in advance.
    The round solenoid valve centre of manifold is lifting a 4000 rpm as it should.
    However I noticed one of the hoses is not connected to anything is this correct ? .
    I have attached a picture and circled the hose in question.
    Cheers.
  2. #2
    ⋆⋆ CF Member ⋆⋆
    Join Date
    4th April 2015
    Posts
    1,437
    Mate, I'm just too jealous of that to be able to help, but someone will post up the answer
    Cress
    95 VR6
    One day she will drive out of my Garage
  3. #3
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    19th January 2006
    Location
    South Manchester + Hazel Grove
    Posts
    118
    Don't know myself, but I found this post on here pointing to the instructions:
    http://the-corrado.net/showthread.ph...=1#post1187326
    Hope it helps...
  4. #4
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    398
    Well there is not one out there for sale at the moment ( standalone) but I noticed there is one for sale on a green VR6 on ebay. You could always put an offer on the car and then swop the inlet manifold and sell it on ?
    https://www.ebay.co.uk/itm/VW-CORRAD...Ajde:rk:1:pf:0
    I think the hose is either meant to be attached to the brake server or its some kind of air escape????????
    I have the original reciept from Stealth it was fitted in 2003 alongside a load of other stuff, Im not sure if the bill was just Labour as I know the Shrick cost a couuple of grand on its own. The bhp is running at 220 with chip apparently. So it could be with parts and labour the guy spent over 8 k on it in one foul swoop which was alot of bloody money in 2003 and still is .
    The shocks are now shot or just to harsh for my taste and the exhaust is a bit tatty. Got a Milltek catback, Bilstein plus eibach springs ready to fit.BMC has been taken off and replaced with an orinal airbox I sourced.
    Notice it says vsr not vgi im sure he just misdecribed it or the owner went from a VSR to a VGI manifold a some point .
    Attached original reciept out of interest.
  5. #5
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,809
    That hose should be connected to the car's vacuum system somewhere I would say - usually done with a t-piece connector, but hopefully someone who actually runs one of these will be along soon and explain. You could also give Vince at Stealth a ring - he's usually very helpful.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  6. #6
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    398
    Thanks Fen,
    Think I have sorted it out, the hose can move only so far in the engine bay becuase of the legnth, and I found a nipple that must have something to to do with the brakes as its attached to the abs pump and the hose fitted on correctly . Please let me know if this is wrong fellow members. Thanks
    Attached picture
  7. #7
    CF-oholic! seanl82's Avatar
    Join Date
    1st September 2011
    Location
    North Devon
    Posts
    5,953
    No, it definitely doesn't fit on that! Thats the bleed nipple for the brake slave cylinder, so unless you wan't brake fluid inside your nice new shiney Schrick, I'd say don't connect it to that!
    95 Classic Green VR6 - Jetex Cat Back|BMC CDA|VT mounts|Bilstein B12s|288mm front brakes|Mk4 Rears|Braided hoses|Daves16v shortshifter|Lupo wipers|Uprated headlight loom|
    http://the-corrado.net/showthread.php?t=79984
    CCGB #3982
  8. #8
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    398
    Ill contact Stealth and see what he says but it does say on the instructions to attach the open hose to the brake server.
  9. #9
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,809
    I think that means to splice it into the main vacuum pipe from the brake servo, or some of the other vac lines.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  10. #10
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    398
    Ha glad I checked first Ive pulled it off and called Vince, going to pop down there this saturday, pretty excited to get it up and running correctly to see what the difference the shrick makes.
    The Reservoir is attached to a T junction hose that goes to vacum pipe from the brake server so just got to get this open hose connected somewhere !
Similar Threads
  1. Shrick VGI question?
    By Hofmiester in forum Engine Bay
    Last Post: 6th March 2014, 11:59 PM
  2. Shrick VGI Issues...
    By adambob in forum Engine Bay
    Last Post: 4th December 2011, 9:18 PM
  3. shrick info please
    By MADFISH in forum Engine Bay
    Last Post: 22nd May 2010, 11:39 PM
  4. Shrick Oil Sump
    By iow_corrado_g60 in forum Engine Bay
    Last Post: 19th July 2006, 12:26 PM
  5. Who needs a Shrick???
    By Mike Edwards in forum Engine Bay
    Last Post: 21st June 2004, 8:18 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
