Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: 1.8t refresh build
  1. #21
    Newbie foster9099's Avatar
    Join Date
    30th July 2018
    Location
    Sheffield
    Posts
    30
    I bought the parts a while ago to rebuild the shifter mechanism, mainly because the centering spring was snapped and made it very hard to select 3rd gear. I bought all the bushes and spring required direct from VW which came to a massive £6 in total. I decided to tackle this job after watching a very useful video on Youtube, I can post the link if anyone is interested.
    The biggest fear it seems is whether this guide bushing that locks into reverse is intact, mine seemed to look pretty good. I don't have any more photos of the process but it is all fairly simple.
    This is the second time the sub-frame went in, first time was the anti roll bar was the wrong way up and therefore hit the steering arms. I will need to lower the sub-frame slightly again as it seems to be impossible to reattach the steering U joint with the sub-frame all the way up. I also still need to install the rubber boots on the steering rack.
    Test fitted the brand new washer bottle all the way from china, the old one looked pretty disgusting.
    The latest delivery is a shiny aluminium radiator designed to fit in place of the original Corrado one, my original one looked in bad condition and probably wasn't helping the much more powerful engine much.
  2. #22
    Join Date
    30th July 2018
    Location
    Sheffield
    Posts
    30
    Time to make a start on the engine, i'm not going to tear down this engine and rebuild it but i will clean it up and replace some seals and gaskets etc.
    First is the sump off, there was far too much rtv used previously. I have also removed the pickup and the plastic baffle in this image.
    There is some bits of metal in the pickup, not really sure what they are from but I cant find any evidence of catastrophe. The pickup and o ring will be replaced with a new genuine part.
    Side note, I finally got the track rod boots. The picture was taken before I got the tool to crimp the retaining clips on.
    I did a quick clean of the engine block and laid down the first coat of paint, I wasn't too worried about the finish as I think I will end up with a different engine at some point to completely rebuild.
    Another side note, managed to get the brake booster/ servo installed. Its a pain to get it lined up while fitting it between the strut tower, a second person inside the car makes the job a little easier.
    The oil filter housing and oil cooler were cleaned up and painted black and the alternator bracket painted yellow. I began to fit everything back to the engine including the thermostat and knock sensors.
    This is a mock fitment of the exhaust/ turbo system to help me remember where everything goes. The turbo is a Chinese K04-001 which is supposed to be a bit of a hybrid K03s, however with Chinese quality. This turbo was supposed to be fairly new when I got the car back end of summer last year, by the time I took it off the road the car was smoking quite bad and losing coolant so I suspect the seals in the turbo are gone. I did have a spare K04-001 turbo that came with the car, I had this spare turbo refurbished by a reputable company who fitted new seals, uprated journal bearings and a billet K04 compressor wheel.
    This was him showing me the difference between the old parts to the new, you can see the oil galleries are much larger in the new parts.
    This is my refurbished turbo, I will be fitting this once I am confident everything else is in place.
  3. #23
    Enthusiast
    Join Date
    16th April 2006
    Location
    Bucks
    Posts
    987
    Think if I had the engine at that stage I'd be tempted to do a set of big end shells at least
  4. #24
    Join Date
    30th July 2018
    Location
    Sheffield
    Posts
    30
    Quote Originally Posted by Geeba View Post
    I was tempted to build this engine but it ran well before apart from the turbo and I want to be driving the car this summer. My plan is to get another engine and rebuild that, most likely with forged rods, while still been able to drive the car.
  5. #25
    ⋆⋆ CF Donator ⋆⋆ 1xshaunx1's Avatar
    Join Date
    14th December 2010
    Location
    near sheffield
    Posts
    495
    Good stuff, well done matey and a good plan. I can see you achieving it at this rate.
    4th one surely the last
  6. #26
    Join Date
    30th July 2018
    Location
    Sheffield
    Posts
    30
    Once I had all the plumbing for the turbo sorted out I fitted my refurbished one
    When I went ahead and compared the 2 turbos side by side, my refurbished turbo has a bigger inlet when is interesting. The turbo on the left (refurbished) was the turbo the previous owner had on the car when it was remapped and when the engine was at its best. They changed the turbo to the one on the right when they had engine failure on the previous engine, they told me that the car was never quite the same afterwards.
    The engine with all the accessories attached.
    The clutch and flywheel was in good condition, the clutch actually didn't look that old but it did slip on me a couple of times. I took everything up to CG Motorsport in Leeds to get something that would handle the extra power. They rebuild the clutch plate to a dual friction material, this is organic on one side and paddle on the other. They also refinished the flywheel and pressure plate and gave it all a coat of paint. Sadly I didn't remember to take a photo of the clutch before it all went together.
    Gearbox on and ready to drop in the car.
    Back in the car.
    At this stage all the engine wiring has been connected and the radiator is test fitted with the top cross member.
    The previous intercooler and piping arrangement was a mess so i'm going to be re-engineering the whole setup. I have some bits of silicone joiners and piping but I will be needing more, I didn't realise how expensive even a simple 90 degree joiner is. Adding all the piping bits I need its easy for it to add up to £50 £60. The image shows the small gap that I have to fit my piping through, there is enough room and it massively simplifies the whole setup compared to what it used to be. The intercooler only just has enough room to fit between the top cross member and the power steering cooler.
  7. #27
    Regular Bauhaus's Avatar
    Join Date
    5th July 2004
    Location
    South East Essex
    Posts
    161
    Thats looking good, coming together quite nicely.
    I was thinking of getting one of those aluminium radiators, how do you rate the build quality of it ?
  8. #28
    Enthusiast
    Join Date
    15th October 2008
    Location
    West Yorkshire
    Posts
    319
    Nice progress, coming together quickly
  9. #29
    Join Date
    30th July 2018
    Location
    Sheffield
    Posts
    30
    Quote Originally Posted by Bauhaus View Post
    Just visually it looks really good actually, the pins fit perfectly in the holes on the lower cross member. The top bracket fits into a little slot just like the original. It comes with a plug in the bottom which I removed to screw in the sensor. So actually for the price i'm pretty impressed with it, the real test will be when I get to running the car.
  10. #30
    Join Date
    30th July 2018
    Location
    Sheffield
    Posts
    30
    You might have noticed the 45 degree bend intercooler pipe that I had originally put on. When I tried to test fit the air filter there was nowhere for the filter to go, I then knew I had 2 options, find a new way of running the intercooler piping or relocate the battery. As it happened a friend has a load of off cut bends of 2.25" stainless steel, I can weld stainless and create a much better fitting pipe run.
    This is what we came up with, the intercooler piping going down underneath where the air filter will sit.
    Here is the pipe joining up to the intercooler. Im very pleased with how this turned out. Now i just need to get a couple of fittings, one for the N75 valve and one for the re-circulation valve.
Similar Threads
  1. Breather hose refresh still small leak
    By Keyo in forum Engine Bay
    Last Post: 19th December 2018, 7:44 PM
  2. Aqua blue pearl refresh
    By maff in forum Members Gallery
    Last Post: 21st December 2016, 9:39 PM
  3. How old is yours, 16V re-build too
    By strimmer in forum Members Gallery
    Last Post: 11th June 2013, 8:55 PM
  4. Call that a build thread? THIS is a build thread...
    By Jim in forum General Car Chat
    Last Post: 6th December 2012, 5:14 PM
  5. F.A.O anyone doing a brakes/steering refresh
    By pete_griff in forum Drivetrain
    Last Post: 14th October 2007, 4:43 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
