Results 1 to 3 of 3
Thread: Engine bay fuel lines Passat fit umm ??
  1. #1
    ⋆⋆ CF Donator ⋆⋆ Keyo's Avatar
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    376
    Today I purchased the fuel lines to the left side of the VR6 engine above the serpentine belt which wasn't easy as the stock ones are now apparently obselete. I wanted to keep oringinal rather then aftermarket. After much searching on the web I managed to purchase one from Germany and the other from a car part hoarder in the UK, both are old but unused stock which I aint chuffed about forking out the best part of 70 quid and not in packaging.
    One thing I did notice was the fuel lines looked the same as Passat VR6 which are available from VW classic parts that are cheaper and new in the box which is reassuring been a fuel line !
    So part numbers as followed for x2 hoses Corrado 021133988K 021133990K
    Passat 021133988J 021133990J
    Has anyone had a punt on the passat hoses to see if they fit the Corrado they look just the same on OEMEPEC.com ?????
    Cheers
  2. #2
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,774
    Hmmm - I was able to buy the stock ones from the dealer 3-4 years ago. Not sure about the Passat ones, but if they are off an early code VR6 they should fit. You can actually just use standard fuel injection piping from any motor factors and bend it to fit - the VW hoses are not anything special, simply shaped to fit the routing. It's a relatively low pressure injection system, so once they they are tight with no leaks or touching anything they should be ok.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  3. #3
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    376
    The stealer said they have been obselete for 4 years so I guess you had last pickings , not sure how you work out if the part is an early code Vr6 my Rado is a 95 run out model.
    Would be good for fellow members to know if the passat ones fit .
Similar Threads
  1. VR6 Fuel Lines
    By daves16v in forum Parts for Sale
    Last Post: 11th October 2015, 2:23 PM
  2. 16 kr fuel lines
    By corradlo in forum Engine Bay
    Last Post: 4th June 2012, 7:53 AM
  3. KR Fuel Lines
    By jslootweg in forum Engine Bay
    Last Post: 18th June 2007, 10:41 AM
  4. Fuel Lines VAG only ?
    By cookie 1.8 16 valver in forum Engine Bay
    Last Post: 31st May 2005, 12:13 PM
  5. VR fuel lines
    By rmn in forum Archive
    Last Post: 15th June 2004, 3:51 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
