Results 1 to 6 of 6
Thread: Vr6 cooling fan stages
  1. #1
    ⋆⋆ CF Donator ⋆⋆ captainredeye's Avatar
    Join Date
    16th May 2009
    Location
    Calne, wiltshire
    Posts
    789
    I have had an issue with the 2nd stage not coming on, I have replaced the fan control module with no luck and have now removed the loom to check for any damage.
    My question is would the actual fan have a fault where by the second stage has stopped working and the fan has the speeds built into it and the fan module is just a sort of switch or is the fan speed controlled by the module?
    CCGB 3172
    88 Silver Mk2 Golf / NEW HOME
    94 Dragon Green Corrado VR6
    03 Jazz Blue Lupo 1.4, named Efole
  2. #2
    CF Nutter fendervg's Avatar
    Join Date
    13th June 2009
    Location
    Dublin, IE
    Posts
    1,969
    Based on this:
    http://the-corrado.net/showthread.ph...-cooling-guide
    ...it could be you radiator temp sensor or the 4-pin yellow sender in the thermostat housing, unless you have already ruled them out.
    ____________
    fendervg
    93 Corrado VR6
    Members Gallery
  3. #3
    Enthusiast 1xshaunx1's Avatar
    Join Date
    14th December 2010
    Location
    near sheffield
    Posts
    429
    You need to turn the ignition on and bridge the 3 pin plug on the bottom of the radiator as described in the guide. If you don’t get the 2 stages to come on as in the guide it’ll be the wiring or the fan control unit where all the wiring goes to. The yellow sensor is for dash temp and after run. Stage 3 is off the black plug in the thermostat housing.
    Bridging the plug does work as it’s how I diagnosed my sender being duff as my stage 1 doesn’t work but when I bridge the plug it comes on great.
    4th one surely the last
  4. #4
    Join Date
    16th May 2009
    Location
    Calne, wiltshire
    Posts
    789
    Well i have bridged the pins and stage 1 is there but not 2, i replaced the module as a couple of diodes had fallen off inside but still no joy, i have removed the loom and have found breaks which are now repaired i will fit it soon and see if i have any luck with it, i was just a little unsure if there was also the speeds built into the fan but im guessing than is controlled by the current so it can't be the fan at fault.
    CCGB 3172
  5. #5
    ⋆⋆ CF Donator ⋆⋆ swiftkid's Avatar
    Join Date
    24th May 2007
    Location
    Near Hull
    Posts
    2,824
    The fan controls the 3 speed but if stage 2 had gone so would stage 3... I think. Basically you have 3 positives and a negative going in, stage 1 goes through 2 resistors, stage 2 goes through 1 and stage 3 is direct 12v. But sounds like you've sorted it anyway
    Red 16v gone
    Red VR32.. WIP
  6. #6
    Join Date
    16th May 2009
    Location
    Calne, wiltshire
    Posts
    789
    Ok, i have tidied up and repaired the loom after removing it i have every thing back in apart from the black plug with the thick red wire which i can't work out where it goes, im not sure if its directly into the back of the fuse box or if there is a wire with the connecting plug hanging around somewhere but i can't see it, any ideas?
    Attached Images Attached Images
    CCGB 3172
Similar Threads
  1. Replies: 0
    Last Post: 4th December 2017, 10:32 PM
  2. Stages of tuning a Valver
    By Flexso in forum Engine Bay
    Last Post: 27th October 2008, 12:23 PM
  3. rear spoiler is rising in stages (need advice )
    By kop10320178 in forum Exterior
    Last Post: 21st June 2007, 11:54 AM
  4. G60 tuning stages and what they are?
    By skid in forum Engine Bay
    Last Post: 16th June 2007, 3:33 PM
  5. Majiks G60 in final stages
    By Majik in forum Members Gallery
    Last Post: 15th April 2005, 9:36 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
