Results 1 to 4 of 4
Thread: Control arm and ball joint replacement - tips
  1. #1
    Enthusiast pfnsht's Avatar
    Join Date
    2nd February 2018
    Location
    Herts
    Posts
    333
    Hi all,
    Noticed a bit of play on the 12/6 o'clock test + a torn boot on the the ball joint. One of my control arm bushes looks a bit cracked too so I've seen some Febi Bilstein control arm + ball joint assemblies for circa £67 ea and plan to replace myself. Does that sort of price sound alright?
    Gaining confidence working on the car but haven't done this job before. I have tools, including an impact wrench & torque wrench.
    On reading I've seen it's advisable to jack both sides up when replacing a ball joint - is this necessary if replacing control arm and ball joint as a ready assembled unit? Reason I ask is because my drive way is slightly sloped and it's easier to jack one side at a time.
    As far other stuff - is it just a couple of bolts on the body/sub frame and off it will drop? Any advice on torque settings?
    Cheers,
    Matt
    1995 White VR6 CCGB Member 4303
  2. #2
    Join Date
    2nd February 2018
    Location
    Herts
    Posts
    333
    Oh and any advice on anything else it might make sense to change/inspect at the same time would be great too.
    The car has just had new shocks, springs and top mounts.
    Cheers
  3. #3
    ⋆⋆ CF Donator ⋆⋆ Keyo's Avatar
    Join Date
    16th December 2018
    Location
    West Midlands
    Posts
    379
    Not sure about torque setting but I purchased a Febi kit waiting to fit off ebay that came with the wishbones and a few other goodies.
    Have you inspected the front droplinks ? There are also four bushes on the front beam , 3 engine and tranmission mounts ,and 2 rear axle bushes.
    Front x 4 bushes beam
    https://www.ebay.co.uk/itm/VW-GOLF-M...72.m2749.l2649
    Drop links
    https://www.ebay.co.uk/itm/Fits-VW-C...72.m2749.l2649
    Front suspension kit
    https://www.ebay.co.uk/itm/FEBI-SUSP...72.m2749.l2649
    Rear axle bushes
    https://www.ebay.co.uk/itm/Febi-Rear...72.m2749.l2649
    Let us know if you want a link for the engine and tranny mounts and Ill pop them over to you as well.
    If jacking on a sloped drive I advise putting a couple of tyres under the car to act a safety cushion if the jack becomes unlodged, only metioned this as it happened to me once and it was one hell of a close shave.
  4. #4
    ⋆⋆ CF Donator ⋆⋆
    Join Date
    24th March 2012
    Location
    Basingstoke
    Posts
    705
    Jacking up both sides is essential if you are doing anything with the anti roll bar. You don’t want the twist in it when undoing anything, broken bones likely.
Similar Threads
  1. Ball Joint Fitting - VR6
    By Dan_Storm in forum Drivetrain
    Last Post: 26th March 2012, 6:46 PM
  2. Ball joint splitter
    By awright182 in forum Drivetrain
    Last Post: 7th October 2010, 11:23 PM
  3. Ball joint replacement
    By pwj in forum Drivetrain
    Last Post: 14th June 2006, 7:58 PM
  4. ball joint
    By s.g in forum Drivetrain
    Last Post: 16th December 2005, 2:17 PM
  5. Ball joint
    By Bora Bora in forum Drivetrain
    Last Post: 16th November 2004, 10:55 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
