Results 1 to 3 of 3
Thread: Need steering rack replacement, may as well do clutch at the same time???
  1. #1
    I need a steering rack replacement on my 93 rado. It leaks like a sieve. The bentley says that you have to drop the subframe to remove the rack (which I believe... I've been under the car too often), but I also kinda need a clutch. Does it make sense to do both at the same time? I'll be paying someone to do this because there ain't no way in hell I'm trying to replace a freaking steering rack in the middle of a canada winter.... by myself.... outside. (Yes I'm aware that it'll be expensive as hell.) I know the transmission removal isn't required for the steering rack replacement, but I'm pretty sure dropping the subframe would allow for easier transmission removal... no?
  2. #2
    Enthusiast
    Join Date
    16th April 2006
    Location
    Bucks
    Posts
    919
    It would allow easier access to the gearbox.. but make sure you have all the necessary engine supports in above.
    I'd wait for Canadian summer and do it myself
  3. #3
    Regular
    Join Date
    15th October 2008
    Location
    West Yorkshire
    Posts
    235
    You don't have to drop the subframe, you can get away with loosening or even just moving the steering column so you can get the UJ out.
    If you do drop the subframe though, then yes it makes gearbox removal a lot easier.
Similar Threads
  1. steering rack boot replacement
    By stevej in forum Drivetrain
    Last Post: 15th November 2009, 3:32 PM
  2. Front pads & Steering rack gaitor replacement....
    By DEL VR6 in forum Drivetrain
    Last Post: 23rd June 2009, 12:55 PM
  3. Replies: 5
    Last Post: 4th February 2006, 6:09 PM
  4. Steering rack gaitor replacement
    By markmcie in forum Drivetrain
    Last Post: 18th August 2005, 4:59 PM
  5. Replies: 8
    Last Post: 28th May 2004, 7:58 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
