Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Brake fluid reservoir full
  1. #1
    Hi guys!
    I recently purchased a 2.0 16v 9A Corrado with ABS, and I am having a break issue.
    My brake fluid reservoir is full to the top with fluid. The brake pedal is spongy. The ABS light goes off after turning on the engine. ABS seems to work just fine. Should I bleed the brakes or just use a hose to empty some of the excess fluid?
    Thanks for the help!
    VW CORRADO 2.0 16v 9A
  2. #2
    CF-oholic! delfinis38's Avatar
    Join Date
    24th February 2006
    Location
    Muckle Flugga & Fastnet Rock
    Posts
    3,399
    Has the fluid been changed recently.... it may have water/ condensation in it, if it's old... you can check it with a guage. But I'd prob do a complete fluid change... bleeding the brakes I find a nightmare on a corrado.
    Corrado VR6 - Aqua Blue LC5U - 96 'N' Plate
    Black Leather - Heated Seats - Air Con
    Totally Standard and intend to keep it that way !
    Hibernation for Winter ! SORN
  3. #3
    Sorry for the newb question but, changing the brake fluid does not imply bleeding the brakes also?
  4. #4
    Regular
    Join Date
    15th October 2008
    Location
    West Yorkshire
    Posts
    244
    Someone has probably overfilled it or replaced the brake pads and pushed the caliper pistons back in without checking the fluid level.
    Grab yourself a Turkey baster from Wilkos/poundshop and suck some of the fluid out. If the car is new to you then always worth doing a full fluid flush and bleeding them up. As mentioned above, bleeding Corrados seems much more difficult than the other cars I've done
  5. #5
    i changed the fluid on my car and the pedal was spongy but after a few hours driving the pedal stiffened up again
  6. #6
    Thanks guy's for all you're answers!
    I'll keep you posted!
  7. #7
    Enthusiast
    Join Date
    23rd April 2017
    Location
    Liverpool
    Posts
    382
    Let gravity do the work.Top up brake fluid place a tight fitting hose over the brake nipple ,crack off the nippel and it will bleed no problems. That’s how l did mine
  8. #8
    Should I do this to the farthest brake cable or ...?
  9. #9
    Join Date
    24th February 2006
    Location
    Posts
    3,399
    If your unsure how to do it, get a pro to do it. From memory their are 6 bleed nipples... 2 in engine bay
  10. #10
    Is it just here or it is very hard to find in someone who has the knowledge and patience to do certain things on older cars
Similar Threads
  1. non abs brake fluid reservoir
    By mimjed in forum Wanted
    Last Post: 21st August 2014, 9:37 PM
  2. brake fluid reservoir
    By chopper666 in forum Drivetrain
    Last Post: 30th July 2013, 7:20 PM
  3. Brake fluid reservoir or cap
    By NewbridgeJob in forum Wanted
    Last Post: 27th June 2012, 11:51 AM
  4. wanted: brake fluid reservoir
    By DuBSterVR in forum Wanted
    Last Post: 9th March 2012, 4:57 PM
  5. changing brake fluid reservoir
    By fla in forum Engine Bay
    Last Post: 8th March 2012, 3:46 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Help us
Follow us
advertising & sponsorship
